Fender Blackface Vibroverb
Roe
Re: Fender Blackface Vibroverb
Post by Roe » Mon Jun 12, 2017 7:34 am
Yeah, that's the aa763 - those are rare and valuable
Freebird
Post by Freebird » Mon Jun 12, 2017 11:45 am
Roe wrote:Yeah, that's the aa763 - those are rare and valuable
Thanks Roe
:thumbsup: Good to know they are rare and valuable. The amp holder told me he has to be very careful if he is doing gigs with this amp. Someone has always to keep an eye on it.
Daniel
Freebird
Post by Freebird » Fri Jun 16, 2017 8:16 am
Hi forum members
Do I have to swap the brown Astron tone caps on the main circuit board: https://www.dropbox.com/sh/fy1uup7kduem ... G_3797.jpg? Can they get bad over time? The blue molded I think rarely need replacement, isn't it so?
Any related input is welcome! Thanks,
Daniel
danman
Post by danman » Fri Jun 16, 2017 9:13 pm
Are you referring to the big, round electrolytic caps on the board? If so, then yes...it's a good idea to swap those also as they are way past their useful life. I also saw a brown drop on your board I believe. They are film caps and they do not suffer the effects of time like electrolytics do.
Freebird
Post by Freebird » Sun Jun 18, 2017 7:54 am
danman wrote:Are you referring to the big, round electrolytic caps on the board? If so, then yes...it's a good idea to swap those also as they are way past their useful life. I also saw a brown drop on your board I believe. They are film caps and they do not suffer the effects of time like electrolytics do.
Hi danman
Thank you for your response. Yes, referring to the big oily paper caps on the cathode: three of them have 2x25uF/25VDC
and one has 25uF/25VDC . I then will swap them too.
The smaller browny ones seems for me also that they are film caps. I let them as they are in.
Daniel
danman
Post by danman » Mon Jun 19, 2017 7:36 pm
Yes...the 25uf/25v are well past their useful life. If the amp is a player, I would want to replace them with fresh caps.
Freebird
Post by Freebird » Sat Jun 24, 2017 5:19 am
danman wrote:Yes...the 25uf/25v are well past their useful life. If the amp is a player, I would want to replace them with fresh caps.
Thanks danman for your confirmation. The amp is a player and has to be it for further 25 or 50 years :D .
Daniel
Freebird
Post by Freebird » Sat Jun 24, 2017 5:37 am
Today I swapped the Astron tone caps (2x25uF/25 VDC) on the main board with new TAD's (2x25uF/25 VDC). After I soldered out the old brown Astron caps I measured them against TAD: Here the approximate values:
Astron: 45-70 uF and ESR 1.9-6.5 Ohm at 1 kHz (a very bad one has 8.5 nF nano! and ESR 28 kOhm kilo!)
TAD: 24-24.5 uF and ESR 0.11-0.12 Ohm at 1 kHz
It confirms, that the old Astron Caps has to be replaced with new ones. Enclosed a picture: https://www.dropbox.com/s/vvkjnvw1b8woy ... 8.JPG?dl=0
Daniel
danman
Post by danman » Sat Jun 24, 2017 8:47 pm
The amp should sound great when your done!!
Freebird
Post by Freebird » Mon Jun 26, 2017 3:39 pm
danman wrote:The amp should sound great when your done!!
Yes danman, it really sounds much better and the amp is more stable. Also there is less hum.
New filter caps: https://www.dropbox.com/s/t4eb1b1ypyv45 ... 2.JPG?dl=0
New tone caps: https://www.dropbox.com/s/x72xrnp5ejeru ... 9.JPG?dl=0
New bias cap: https://www.dropbox.com/s/3m4g1zt694t73 ... 7.jpg?dl=0
Additional grid stoppers: https://www.dropbox.com/s/qtu1aui87dg8j ... 8.jpg?dl=0
I hope my guitar friend is satisfied and happy with my job.
Only if I watch the small new bias cap I am a little bit scared. I hope it is a good one?!
Daniel
Post by neikeel » Mon Jun 26, 2017 5:10 pm
Thanks for sharing that.
Still hanker for a nice clean BF Fender, waiting for BFDR to fall into my lap in the same condition as that one!
Freebird
Post by Freebird » Tue Jun 27, 2017 12:32 pm
neikeel wrote:Thanks for sharing that.
My pleasure! It was fun to restore such an old amp. Thanks to all of you who helped me to come through!
Don't know how many Blackface Vibroverb AA763 from 1963-64 are made by Fender? Anyway, I wish you good work on your Blackface Fender!
Daniel
