Lar/mar in Liverpool style amp
Anyone ever installed a mas. Vol.in a Liverpool?Im not sure where you pull off the board.My metro 50 went well and works great.I would like to try to install it in this build,Thanks,Mikey
Re: Lar/mar in Liverpool style amp
I have - a LarMar into my homebrew TW Liverpool clone. works just as you'd expect - no issues whatsoever.
Here's a pic, though this was taken before I put in the LarMar and was trying a half power switch (it sucked), but good for your reference. I put the pot in the hole in the chassis on the front panel - you can see it peaking out behind that cap on the presence pot (middle, top of pic). The wiring off board is the exact same as you would a Marshall 50w.
http://i912.photobucket.com/albums/ac32 ... hassis.jpg" onclick="window.open(this.href);return false;
Here's a shot of the front where the location is obvious:
http://i912.photobucket.com/albums/ac32 ... 0_1701.jpg" onclick="window.open(this.href);return false;
I'll see if I can find a pic of it installed tonight and post a link if so. Ampgarage has several threads on this topic too. Good luck.
Chris
Chris
Link to how I installed it:
http://i912.photobucket.com/albums/ac32 ... LarMar.jpg" onclick="window.open(this.href);return false;
Thanks Brother,Nice amp!!!Very helpfull.I got the parts yesterday so Ill give it a shot.Thanx for the pics,Mikey
- JimiJames
- darkbluemurder
I also had one in a Liverpool style amp. It worked well to tame loudness. Of course the EL84 were no longer being overdriven at low settings.
The amp has been since rebuilt into something different.
Cheers Stephan
Cheers Stephan
