Will boost/cut work in this FX loop ?
Posted: Sat Sep 15, 2012 4:26 am
I have a Soultone 45ME3 (based on JTM45/Plexi). It has quite a few features such as power scaling and fx loop.
Now, I would like to use a boost or cut pedal in the loop to raise volume for solos (or cut for rhythm), but I'm not sure that will work.
The manual for the amp has the technical data
http://www.soultoneamps.com/FortyFive/d ... Manual.pdf
The relevant part is:
I am also unsure if I want a boost or cut pedal, as the amp isn't really that loud (in a 2 guitar band) and I sometimes find myself running out of headroom, so I suspect boost won't have much room left to work on.
Any comments are welcome, thanks
And also thisV3 acts as an effects loop buffer tube, adjusting the level of the signal down to effects unit level, matching the impedance
of effects units, with variable send and return level controls. Return instrument feeds are then boosted back up with
another cathode follower, and matching the impedance for the phase inverter stage.
So with this in mind, will boost in the loop have any effect on volume or will it just result in more drive ?...control is a Post Phase Inverter Master Volume control,
