Fryette amp anyone??
tone?
Post by tone? » Thu Aug 01, 2013 1:52 pm
ok who has the balls ( or brains ) to provide any insight on making this amp a bit looser and give it a tad more mids? :wink:
Its a 50 watt pitbull . really nice sounding amp. I play it now in Tube rectifier mode with a 5AR4. I tried a 5U4GB bit it got too mushy.
The SS rectifier mode is too tight though.
Would lowering the filtering give it more compression and a looser feel? more touch sensitive?
without getting too loose as the 5AR4 did?
cheers!
alexradium
Re: Fryette amp anyone??
Post by alexradium » Mon Aug 05, 2013 2:46 am
is there a filter choke?
to get more mids is possible but i need to know what's in the circuit,preamp tubes bias resistors and coupling caps,the tonestack values.
hopkinWFG
Post by hopkinWFG » Mon Dec 02, 2013 9:01 pm
Mallory caps ? If I recall the last time I opened up my 50CL it isn't mallory caps... Is it stock amp we have here?
tone?
Post by tone? » Wed Dec 18, 2013 2:47 am
absolutely stock , cant you see the dates on the caps?
016hnoor
Post by 016hnoor » Tue Mar 17, 2015 3:37 am
NOOR
nofarewell
Post by nofarewell » Mon Oct 30, 2017 12:43 pm
Sorry for resurrecting, do you know if there are any layouts/PCB/PTP info on this amp?
I'd like to build it.
