I'm bumming again!! My Bassman is down again!! It is a handwired '59 Bassman with all high quality components, everything has been upgraded, Merc Transformers, frickin' Top of the line speakers and capacitors etc... I haven't played it in about 2 months, I have been moving. Fired it up to play a festival last week and it hums like crazy. was fine at the old house. took out tubes, changed tubes, still hums. How do I figure out if it is a transformer, filter caps etc... Thanks
Dax
'59 Bassman Replica
- Dax-The-Ax
- Dax-The-Ax
Re: '59 Bassman Replica
Although I noticed a ground wire attached to my Master Volume Pot came off, could this have fried a tranny? Here is a pic of part of the guts.
- (96.42 KiB) Downloaded 768 times
how is that MV wired?Dax-The-Ax wrote:Although I noticed a ground wire attached to my Master Volume Pot came off, could this have fried a tranny? Here is a pic of part of the guts.
If you experience hum,it could be either a bad connection,a tube,or a bad ground system where you are powering it,or some other piece of equipment like stage lights radiating in the circuit.
If one wire has come adrift highly likely another has done the same somewhere, if it hums now and did not before you have to think a ground wire somewhere.
- Lefty Lou
Hey Dax-The-Ax, what are the brand of polarized orange electrolytic caps as seen in your 59' Bassman Replica amp? Are they NOS caps?
