T.C. Jauernig Luxury Drive
- Flames1950
First off I NEVER hang out on eBay and BIN things I really don't need or have cash for. So don't even think that. Certainly not when I'm in the mood for a different boost pedal.
So whoever it was that commandeered my eBay account and BIN'ed the T.C. Jauernig Luxury Drive boost and had it shipped to me at work, thank you, I can't wait to try it out.
Vintage Guitar claimed this thing sounded so good that it would make any guitar and amp combo sound better no matter how good they already sounded. I'll find out soon.
- Flames1950
No, my eBay handle is marshallrocks.
It took some covert operations to get home and try this thing out for a half hour. Some quick thoughts:
1) This thing is picture perfect if you like playing a clean amp (say a Fender Twin) with an overdrive pedal, but still need a solo boost. I dialed my '75 50-watter clean with a Strat and an old Marshall Bluesbreaker pedal, with the Luxury Drive kicking the Bluesbreaker. As promised in VG's review it added the extra body and upper end zing to bring out lead lines through the Bluesbreaker. The dial is insane -- you barely need to crack it open more than 1/4 of the way to kick another overdrive.
2) Crank the Marshall 50-watt up for some distortion and scrap the Bluesbreaker pedal and I think the Jauernig whoops the FatBoost as a stand-alone boost as well, with less knobs to twiddle. Plenty of sustain with my Strat, again it adds some upper end zing but not in a harsh way, it stayed creamy. But also as always, taming the lows on the percussive Strat sound is a trick, you can make mush pie with ease if you're not careful.
Grabbed the Les Paul for a quick ride before I had to shut down. The Luxury Boost let me knock the Marshall down in the 5-6 range from its usual setting of 7-8 on the volume, enough to just get that old style Free or AC/DC crunch. With the Jauernig set once again at only about 1/4 of the way up the knob, it takes care of boosting the input wonderfully for solos, again giving a touch of treble boost and loads of sustain while remaining utterly clear.
Sometimes it seems like a little too much treble boost, but I didn't have any bass or drums going, that's an impression in isolation which doesn't mean much. I suspect that in a band situation it's going to prove to be just right for the extra cut you need to get your sound out in front.
Very impressive for half the price of the FatBoost (I won't even mention how much cheaper than the TMB, but then it doesn't have switchable modes either.) It also has its transistor in a socket so you can try different transistors for more or less gain and slightly different tonality.
COOL!!
COOL!!
- dirtydeeds22
- Flames1950
Damn this thing kicks butt. I had more time to play with it tonight, so I finally hooked the Luxury Drive and the FatBoost up for a little A/B shootout.
With one knob to its name the Luxury Drive kicks the FatBoost big time. As before, with the gain knob at barely one-quarter of its available range it never failed to push the amp into overdrive glory with just the right high-end sparkle, sustain and attack. The FatBoost couldn't come up with the same cut no matter how I dialed it in, it always seemed like I had to fight it for the picking nuances that the Luxury Drive just hands over like no big deal. You can leave the FatBoost on and then kick in the Luxury to get the attack back, but why, when you could just use the Luxury Drive??
You guys that are looking for a clean boost need to pick this thing up. At $90 it's a freakin' STEAL!!
- thunder970
- Country Boy Shane
I've never heard of this maker. Do they have a site?Flames1950 wrote:Damn this thing kicks butt. I had more time to play with it tonight, so I finally hooked the Luxury Drive and the FatBoost up for a little A/B shootout.
- Flames1950
- Country Boy Shane
Here's a link, he looks like he has some cool stuff. I may have to give it a try.
http://mypeoplepc.com/members/tjauernig ... index.html
What good is my wisdom
When there are no words to say
How I feel everday ?
- thunder970
Question? on my 900 100 watter I don't even play on the lead channel because of all the clipping diodes and op amps. I play on the classic channel with the gain on 9 and master on 5 or higher for a good chunky classic crunch. Do you think this will allow me to back off the preamp gain a bit more and just drive the amp more for that same gain that I have now with a little more picking naunces? It sounds very classic now with great bottom regardless what people say about the 900, but is has to be cranked. I have used alot of overdrives, vintage compressors and everyone thinned my sound when on. Is it a possability this will do the same? As of now I have no clean channel (which is no problem ) I just roll down the volume on my guitar and it gets a classic crackle clean. OR just get a THD HotPlate?
- dirtydeeds22
- Flames1950
Well, I liked it so much that the FatBoost has already been sold on eBay, as wel as my Tube Screamer RI which I haven't used much since I bought it anyway.
Otherwise I've pretty much said it all above. This thing kills me with its ability to add crisp zing and mucho sustain to either my Strat or my Les Paul (and the Les Paul really didn't seem to need any help there, but the sustain is near infinite now.) And I can't imagine how much grit this thing could wring out of an amp, I've never even turned the gain knob more than a third of the way up.
I still think for $90 BIN on eBay you can't go wrong with it.
- dirtydeeds22
