JEN Crybaby
ohmygodtheykilledkenny
JEN Crybaby
Post by ohmygodtheykilledkenny » Mon Oct 03, 2011 4:57 pm
I can buy one for 100$, apparently working. Made in Italy, model 310.001.
Worth checking out?
Re: JEN Crybaby
Post by ohmygodtheykilledkenny » Sat Oct 08, 2011 7:40 pm
Alright, picked it up for $80! Red fasel, has the Ducati non-polarized cap.
Swapping the white box shaped 0.22uf caps for a pair of 100v Mullard Tropical Fish. Just rebuilt the switch.
I'll post clips of it once I get a chance to post clips of my latest homemade fuzz.
Edit: also swapping the trannies for a pair of NOS BC108's.
Travis
Re: JEN Crybaby
Post by ohmygodtheykilledkenny » Mon Oct 10, 2011 11:24 am
This wah is so sick. It needs new trannies though, very hussy mid sweep. The only problem is that I'm having trouble determining the pinout of the Bc170b. Hints?
yladrd61
Re: JEN Crybaby
Post by yladrd61 » Wed Oct 12, 2011 4:17 am
Google the data sheet for that transistor, I have BC108c s in my Experimental Clone Wah, try wiring a 100k mini pot in parallel with the the inductor where the 33K/100K resistor goes and then you can tweak the Q to get the best sound :jimi:
PS: If you have carbon comp resistors check them with an ohmeter to make sure they are within spec so your transistors are not biased too hot ;)
Re: JEN Crybaby
Post by ohmygodtheykilledkenny » Wed Oct 12, 2011 10:48 am
Hey man, thanks for the reply! They are mostly carbon film, couple are pihers, though that is on the to do list. I've looked everywhere man! No datasheets with pinouts!
Re: JEN Crybaby
Post by ohmygodtheykilledkenny » Fri Nov 18, 2011 12:29 pm
Swapped to Bc108's, now the wah is very weak and quieter, hfe of the transistors was about 420. I've got shows this weekend so I can't do anything till Sunday at the earliest but does anyone know what could be the problem? I can post some pics on Sunday if that would help.
Thanks,
Travis
Re: JEN Crybaby
Post by yngwie308 » Wed Feb 08, 2012 9:54 pm
The Jen Crybaby I purchased new from Jim's Marshall shop in London back in 1969, still the best wah I have heard, Vox, you name it.
Worth saving.
Re: JEN Crybaby
Post by ohmygodtheykilledkenny » Thu Feb 09, 2012 1:10 pm
Mhm! I gotta swap transistors again. It sounded amazing but noisy, then I installed one bc108 with the wrong pinout and after correcting it the wah sounded really weak. So I think I probably fried one. :P
HTH
Re: JEN Crybaby
Post by HTH » Thu Feb 09, 2012 6:36 pm
all those old metal cans with the tab on the side are EBC from the tab and looking at the bottom of the transistor.
if you have a DMM with a diode function you can work out what the pinout is, it's just two diode junctions after all.
garbeaj
Re: JEN Crybaby
Post by garbeaj » Thu Feb 09, 2012 6:41 pm
I'd love to see a pic or two:)
Re: JEN Crybaby
Post by ohmygodtheykilledkenny » Thu Feb 09, 2012 10:11 pm
HTH wrote:all those old metal cans with the tab on the side are EBC from the tab and looking at the bottom of the transistor.
I did know that actually, but I thought the original transistor had a different pinout (couldn't find a data sheet). I have several more bc's kicking around so I might get it done this weekend.
garbeaj wrote:I'd love to see a pic or two:)
Pm me your email and I'll shoot you gut shots. :wink:
garbeaj
Re: JEN Crybaby
Post by garbeaj » Fri Feb 10, 2012 11:54 am
I wasn't so much interested in the guts as the outside of the pedal...I'm a very superficial person :wink:
