How to test audio cables?
- FL6
Is it just a simple ohms resistence test with your multimeter or is there a more reliable way?
- clinchfx
Re: How to test audio cables?
Yes, you can test a cable with a multimeter.
For a guitar cable, you have to test three ways:
Tip of one end to tip of the other end. This should read very low Ohms. Remember that even your meter leads can have a few ohms resistance, so you probably will not get zero Ohms. If your meter has a continuity test function, it should beep.
Do the same test between the sleeve of one end and the sleeve of the other end.
If both measure OK, test between the tip and sleeve at one end. This should read open circuit or no beep.
Using a meter is fiddly. If you need to test a lot of different cables, there are a number of test boxes available that can test guitar, XLR, RCA and other cables. There are some at http://www.seismicaudiospeakers.com/Cab ... -s/380.htm If you are into DIY, there are schematics around the internet for making your own.
You just plug the cable into the appropriate sockets in the box and select the appropriate function.
Peter.
Peter.
- FL6
Thanks I will test that out.
- 54strat
After checking with a meter; plug one end into a guitar, the other end into an amp, turn everything on and up, then shake the cord around a little. Any change in sound/noise? Do you hear any microphonic like noise? Yes-replace it. No-you're good.
73 Marshall 1987
87 Fender Stratocaster
- FL6
This worked the best. I wiggled one cable and it was loud and when I took the end apart the copper was completely severed. I looked at the other end and only a few strands were hanging on.54strat wrote:After checking with a meter; plug one end into a guitar, the other end into an amp, turn everything on and up, then shake the cord around a little. Any change in sound/noise? Do you hear any microphonic like noise? Yes-replace it. No-you're good.
- 54strat
I'll have to admit to being a bit of smart aleck on that response
I am just not a believer in paying huge money for high end cables, or worrying about them much in general. I'm fine with Horizon's for about a dollar a foot. Use them until they go south, go get some new ones. I just replaced a pair I'd been using for over fifteen years because they were getting noisy...the outer pvc will dry out and crack over time, and being stomped on with boots doesn't help either.
Even the cheapest cords available now are better than what Hendrix used
73 Marshall 1987
- FL6
But what can wear them out...weather?54strat wrote:I'll have to admit to being a bit of smart aleck on that response
- 54strat
The answer to this is in the previous post. I used my last pair of cords for 15 years. Over time the outer rubber/PVC will deteriorate/dry out and cracks will appear. Stepping on them with hard shoes can break up the braided shield and this is when a cord will start getting noisy, make crackling sounds when you move around on stage.
73 Marshall 1987
