I've read the manual and still don't understand exactly what it does. It says the verb still works after you bypass the pedal??? I'm confused..please help.
FYI, I don't own this yet. Currently shopping for a good plate verb pedal for less than $200. The Hardwire and TC HOF are on my list.
Hardwire Reverb Pedal - what does the tail switch do?
Peavey Classic 30
http://m.youtube.com/watch?v=9kgRpS2dY8M&feature=plcp" onclick="window.open(this.href);return false;
Landry LS100 G3
http://youtu.be/76xxldz_Tj4" onclick="window.open(this.href);return false;
http://youtu.be/7OlOp5TA5Js" onclick="window.open(this.href);return false;
Landry LS100 G3
- MacGaden
- Wiki Editor
Re: Hardwire Reverb Pedal - what does the tail switch do?
If you run it as true bypass, the reverb will stop when you turn the pedal off. With the "Tail" switch engaged the reverb will continue, spill over after you turn it off, which sounds more natural.
MacG.
So, more of a "hard cut-off" of the effect verses a "fade" when switched off, right? I guess that could be useful when transitioning from a solo back to rhythm guitar. Any other situations when you'd want to have if fade off?MacGaden wrote:If you run it as true bypass, the reverb will stop when you turn the pedal off. With the "Tail" switch engaged the reverb will continue, spill over after you turn it off, which sounds more natural.
Thank you!
Peavey Classic 30
Landry LS100 G3
Landry LS100 G3
