fuzzface transistors
pancri
Post by pancri » Mon Jul 16, 2012 9:25 am
hi,
i have a jimi hendrix fuzzface, i read that sound better if you adjust the trimmer under the board...
which is the right voltage on the transistors?
can someone tell me how to measure the voltage on a transistor?
HTH
Re: fuzzface transistors
Post by HTH » Mon Jul 16, 2012 11:03 am
'Better' is subjective to say the least.
Broadly speaking, you want to bias the collector of Q2 to half of the supply voltage, i.e. around 4.5v
However, you may prefer the tone with the collector set at 6v - there is no right or wrong as long as it sounds good to you.
Post by Roe » Mon Jul 16, 2012 5:15 pm
yeah, 4-6v depending on taste
pancri
Post by pancri » Mon Jul 16, 2012 6:58 pm
ok thank you!
how can i measure the voltage on Q2?
yladrd61
Post by yladrd61 » Tue Jul 17, 2012 1:25 am
Measure with a voltmeter between the collector of Q2 and ground, mine sounds best at around 5.2 V :jimi:
pancri
Post by pancri » Tue Jul 17, 2012 7:38 am
ok!
is the collector the one covered with a little gum tube ?
HTH
Post by HTH » Tue Jul 17, 2012 10:26 am
pancri wrote:ok!
Just measure them all till you get the one within the range of 4-6v. The other two (base and emitter) will measure only around 0.8v and 1.4v, so it's easy to identify the collector.
