Diy Attenuator
RiffRaff
Diy Attenuator
Post by RiffRaff » Tue Nov 20, 2012 8:26 pm
In case anyone needs one. I`ve built a couple of these and they work great!
http://www.guitarplayer.com/article/pow ... roject/930" onclick="window.open(this.href);return false;
stef
Re: Diy Attenuator
Post by stef » Tue Nov 20, 2012 9:33 pm
:thumbsup:
axeman
Re: Diy Attenuator
Post by axeman » Tue Nov 20, 2012 9:40 pm
I think I got that one from Stef. :rock:
jimmyride
Re: Diy Attenuator
Post by jimmyride » Sun Nov 25, 2012 11:11 am
Nice, thank you ! I'm gonna try one for sure.
jimmyride
Re: Diy Attenuator
Post by jimmyride » Sun Nov 25, 2012 5:45 pm
Is there an another supplier who has all these components in EU though?
bdc
Re: Diy Attenuator
Post by bdc » Thu Jun 02, 2016 8:58 pm
Is this a lot of attenuation? Using this thing....
and will the cheap duralast heat sink from autozone work OK?
Take that expensive Mouser heat sink out of the picture and it becomes way more appealing..
Would this stuff be any good?
http://www.amazon.com/Super-Lube-98003- ... 4NI2M2#Ask
Haze13
Re: Diy Attenuator
Post by Haze13 » Fri Jun 03, 2016 2:08 pm
I've burned 50 watt power resistor (in aluminum case) with a 30 watt power supply, even though it was on a heatsink. What I am saying is that these resistors are rated for their wattage only when they are "cold" enough.
The "Brown Devil" type resistors are far superior in that matter, they do not need heatsinks. Look at "Rock Crusher" by Rivera, they use these types of resistors. By the way... The cooler they are, less noise will you get.
Just my 2 cents :)
bdc
Re: Diy Attenuator
Post by bdc » Sat Jun 11, 2016 5:25 pm
Thanks haze-- I have an air brake build I did that I'm pretty satisfied with-
No heat sinks/ compound in that build... not sure if the resisters are the brown type you describe but suspect they are-
Think I'll avoid this one...
