Diy Attenuator
Posted: Tue Nov 20, 2012 8:26 pm
by RiffRaff
In case anyone needs one. I`ve built a couple of these and they work great!
http://www.guitarplayer.com/article/pow ... roject/930" onclick="window.open(this.href);return false;
Re: Diy Attenuator
Posted: Tue Nov 20, 2012 9:33 pm
by stef
Re: Diy Attenuator
Posted: Tue Nov 20, 2012 9:40 pm
by axeman
I think I got that one from Stef.
Re: Diy Attenuator
Posted: Sun Nov 25, 2012 11:11 am
by jimmyride
Nice, thank you ! I'm gonna try one for sure.
Re: Diy Attenuator
Posted: Sun Nov 25, 2012 5:45 pm
by jimmyride
Is there an another supplier who has all these components in EU though?
Re: Diy Attenuator
Posted: Thu Jun 02, 2016 8:58 pm
by bdc
Is this a lot of attenuation? Using this thing....
and will the cheap duralast heat sink from autozone work OK?
Take that expensive Mouser heat sink out of the picture and it becomes way more appealing..
Would this stuff be any good?
http://www.amazon.com/Super-Lube-98003- ... 4NI2M2#Ask
Re: Diy Attenuator
Posted: Fri Jun 03, 2016 2:08 pm
by Haze13
I've burned 50 watt power resistor (in aluminum case) with a 30 watt power supply, even though it was on a heatsink. What I am saying is that these resistors are rated for their wattage only when they are "cold" enough.
The "Brown Devil" type resistors are far superior in that matter, they do not need heatsinks. Look at "Rock Crusher" by Rivera, they use these types of resistors. By the way... The cooler they are, less noise will you get.
Just my 2 cents
Re: Diy Attenuator
Posted: Sat Jun 11, 2016 5:25 pm
by bdc
Thanks haze-- I have an air brake build I did that I'm pretty satisfied with-
No heat sinks/ compound in that build... not sure if the resisters are the brown type you describe but suspect they are-
Think I'll avoid this one...
