Squealing Wah Wah
Dave1992
Squealing Wah Wah
Post by Dave1992 » Sat Mar 05, 2016 11:02 am
Hi guys! Just wondering if that was normal to some extend but my wah pedal ( the new cry baby mini set on the vintage mode) squeals like a crazy banshee when it's turned on at high volume. It goes away when I turn down my guitar volume and doesn't squeal when I'm playing the wah.
My signal path goes like: Guitar- Nano Muff- Wah- Phase 90- Catalinbread Belle Epoch- Boss tu3 then to my 59Ri plexi.
Can it be a microphonic inductor? I've read somewhere that some people just wax potted them like guitar pickups. For the moment I think I'll just put some regular foam inside to see if it helps.
Any thoughts are welcome!
Dave
chrisom
Re: Squealing Wah Wah
Post by chrisom » Sat Mar 05, 2016 12:05 pm
That happened to me. I had bought a used Dunlop wah that somebody changed the gear teeth position on to get a different part of the frequency 'throw' range. After I experimented with the pot range and reset it to 'stock', the problem disappeared. I ended up doing it on my other wah that didn't squeal. They both sound way better now. :listen:
Dave1992
Post by Dave1992 » Sat Mar 05, 2016 12:11 pm
chrisom wrote:That happened to me. I had bought a used Dunlop wah that somebody changed the gear teeth position on to get a different part of the frequency 'throw' range. After I experimented with the pot range and reset it to 'stock', the problem disappeared. I ended up doing it on my other wah that didn't squeal. They both sound way better now. :listen:
I don't understand what you mean by "the gear teeth"... Would mind explaining a bit please?! :)
Dave1992
Post by Dave1992 » Sat Mar 05, 2016 12:37 pm
Just found this http://www.seymourduncan.com/blog/the-t ... -wah-pedal
Gonna try it out if it helps!
chrisom
Post by chrisom » Sun Mar 06, 2016 2:31 am
That's exactly what I was talking about. Too far travel on the bright end was causing my squeal problem.
Dave1992
Post by Dave1992 » Sun Mar 06, 2016 8:01 am
It took care of the squeal, thanks alot! ;)
chrisom
Post by chrisom » Sun Mar 06, 2016 11:18 am
No prob. Welcome to the website! :rock: :rockon:
