ep3 pre amp
fixer2
ep3 pre amp
Post by fixer2 » Wed Jun 08, 2016 8:51 pm
Hi Iam just getting into making some of my own effects pedals from getting the parts myself I have done alot of kit ones .I got the ep3 pre amp parts from valve storm is there a betteray out drawng of the front side and the back side of the bread board for the pedal clone I can not find even a lay out drawing for dunlops looks really simple I like to see some pictures of ones other people have built ,that might help me learn how to read schematics better
bigsmitty
Re: ep3 pre amp
Post by bigsmitty » Wed Jun 08, 2016 8:59 pm
Aion electronics makes a pcb
bigsmitty
Re: ep3 pre amp
Post by bigsmitty » Wed Jun 08, 2016 9:01 pm
Aion electronics makes a pcb. And has great documentation on their website
fixer2
Re: ep3 pre amp
Post by fixer2 » Tue Jun 14, 2016 8:03 pm
Does any one that has built from the parts sold by valve storm the EP3 pre amp have pictures of tting together the pre amp just like to see them so I get my layout nice and neat
fixer2
Re: ep3 pre amp
Post by fixer2 » Tue Jul 12, 2016 8:51 pm
could I use poloerized s that are rated for higher voltage like left overs from my amp build rated for 400v or would they not work because of only having 9 volts in a effects pedal?
Haze13
Re: ep3 pre amp
Post by Haze13 » Wed Jul 13, 2016 2:02 pm
They will work. You can see caps like the ones that are being used in tube amps, that are rated for 250v-400v volts in a regular pedals. Not often though... Some times you just can't find right values of specific type of capacitors.
fixer2
Re: ep3 pre amp
Post by fixer2 » Sat Jul 16, 2016 8:14 pm
ok I will look some more but if I can not find them I will use what I have thanks
