Dunlop kickswitch and foxrox wah buffer
mdc1
Post by mdc1 » Wed Feb 22, 2017 10:29 pm
Hi
Installing a foxrox wah output buffer in one of my wah pedals. However I would like to add one of those Dunlop kick switches to the side of the wah to completely remove the the foxrox buffer out of the circuit when needed (wah without output buffer).
Here is the Dunlop kick switch but cannot figure out how to wire this thing up as it came with no documentation or wiring diagram. Weird
http://store.jimdunlop.com/p/ecb233-switch-pcm-ea
Anyone done this before?
Haze13
Re: Dunlop kickswitch and foxrox wah buffer
Post by Haze13 » Sat Feb 25, 2017 1:12 am
If you do not use old fuzzez or any effect, that doesn't have input buffer in it - you do not this output buffer.
However, if your Wah doesn't have INPUT buffer, I strongly recommend you to use one - constantly.
And first transistor with Hfe close to 500 :)
Best Regards
Vadim
