Not sure if anyone can help out here.... Think i need to re-wire my el-cheapo a/b box to switch between or combine two separate amps (100w 1972 Super Lead + Danelectro 30 watt w/ 8" speaker). At the moment its creating a ground loop hum with any of my guitars in any combination --- I've been through all the usual ground check things, guitar cables - and dont subscribe to the 'just lift the ground wire' routine.....
I'm sure its a simple operation, maybe it needs additional components, etc.... looked around the web, but can find a suitable circuit plan... anyone got any clues??
....oh yeah George, the shirts look cool!
thanks in advance,
zeeb.
A/B Box Circuit - Help Please!
- zeeb
- VelvetGeorge
- Site Owner
- zeeb
thanks for the reply, George ----
....nope. no relays - its just a passive circuit, with a 9v battery for 'added red light effects' ....! one line/guitar in, two switches & two outs -- plus and additional aux in/out for a tuner,etc...
maybe a relay thing IS needed to switch the ground between the two sends to the amps ??? not sure how i'd switch the amp input grounds...
hmmm.....
i'll post a clearer pic or diagram later...
zeeb.
hmmm.....
zeeb.
- flemingmras
OK, since you have individual On/Off control of each channel (A and B), that would be kind of hard to use to toggle between A and B.
Here's a little schematic that would work well in that box. Granted it doesn't provide LED status, but that wouldn't be to hard to add with either a relay or using 3PDT switches for the footswitches.
This circuit uses 2 DPDT Carling style footswitches. It grounds the channel not being used, therefore grounding the input to the unused amp.
Hope this helps.
Jon
Hope this helps.
Jon
- zeeb
Hey Jon ---
Thanks loads for that -- will go check a local store for Carling switches -- and brush up on my limited schematic reading! -- seemed a simple thing but i wasnt sure where to start ....
Thanks again -- will let you know how i get on...
Just finished buliding a new guitar - an old 60s' italian (eko? vox?) jazz body & neck w/ two firebird pick-ups... tried it today though the Marshall, and jeezus - it sounds amazing.
speak soon,
John Lee.
speak soon,
John Lee.
- dosmun
- zeeb
