EQ in effects loop
thunder970
EQ in effects loop
Post by thunder970 » Fri Dec 17, 2004 11:23 pm
Do any of you use Eq's on your amps? I was thinking of putting one in the effects loop on my 900 to fine tune the mids a bit. Give me some options here on what works.Thanks
Never being in a band sux :-0
Eoin
Re: EQ in effects loop
Post by Eoin » Sat Dec 18, 2004 10:07 am
Can't really recommend any EQ pedals myself. Boss and Danelectro are not particularly good, from experiences I've had with them. But 9 times out of 10 people are using EQ to vainly try and make up for a bad amp tone, which is more timbral than spectral imo.
Where in the signal path is the effects loop on a 900? I've had a few in the studio but no one seems to use the loop. A nice parametric valve eq might add some distinctiveness to your sound. But if you have that kind of money... there are amps that don't need eq.
Necrovore
Post by Necrovore » Sat Dec 18, 2004 10:56 am
The first Marshall I owned was a 3210 The MOSFET100. I used an MXR 6 band in the effects loop. Made that amp own for what it was. Sure it couldn't compete with a tube amp but smoked any other SS amp out at the time setup like that. They work good, just watch out for noise levels. Putting a noisy eq in the loop like that only amplifies the noise moreso than running it through the front of the amp. You can counter this if its too bad using a hush pedal, just set it so it just barely gets rid of any hiss off the pedal.
Country Boy Shane
Post by Country Boy Shane » Sat Dec 18, 2004 11:46 am
Uh pedal EQ... gross.
Just Feel it MAN! -Shane Gorski "Country Boy Shane"
www.flickr.com/photos/shanegorski
Guest
Post by Guest » Sat Dec 18, 2004 12:07 pm
nothing wrong with the tone, I think with the 4xV30's , SED EL34's and the telefunken's in the preamp sounds smoother than all the dsl,tsl amps that I heard. I'm not a gain freak anyhow, so my amp don't sound anywhere near the buzzy chainsaw no tone high pitched no mids all bass newer amps. I would just like more Eq to play with. I don't "need" it. I'm just wanting to try new things.
Necrovore
Post by Necrovore » Sat Dec 18, 2004 12:29 pm
Country Boy Shane wrote:Uh pedal EQ... gross.
You use what works.
Eoin
Post by Eoin » Sun Dec 19, 2004 8:10 am
Yeah, I think it'd be interesting. Personally, if the effects loop is operating at line level, I'd get a DBX 2031 (on ebay :) ) and play with that. If it doesn't work for you, you can always find a use for it elsewhere. A thing to bear in mind with any active EQ is that you should always cut rather than boost where possible.
dosmun
Post by dosmun » Sun Dec 19, 2004 10:48 am
That is the best advice for an EQ on a guitar. Especially with pedals, the noise increases greatly when you start boosting frequencies.
Post by Flames1950 » Sun Dec 19, 2004 3:18 pm
Actually that's good advice whether guitar or anything else. Boosting frequencies cuts into the available headroom your amp has. Not as big a deal in our distorted guitar amps, but a VERY big deal in your PA system!!
