Page 3 of 5
Posted: Sat May 17, 2008 8:58 am
by novosibir
@ TubeGetter
Mike, is there anywhere a list with the Tungsram data codes in the web, to check from which year they are? Or do you have a data code list?
I've checked all my orig. Tungsram labelled tubes and found 41 different data codes on it, which are as follows:
07D; 1T; 2W; 290; 490; 4H; 58; 6G; 7I; 7T; 73; 8C; 8M; 8Y0; 9T; AT; D4; E2; E7; G1; G8; G9; H1; H5; H90; I8; I90; M6; M8; M9; MY0; O8; R8; RI; SC; T9; TH; X9; Z1; Z70; ZN
Thanks!
Larry
Posted: Sat May 17, 2008 10:42 am
by TubeGetter
Larry, I got ahold of the original table and then re-did it so it would be easier to read (yeah it took a lot of typing). After that I put it in .pdf format. It's for my tube pages that aren't up yet, but here it is:
http://www.cathedralstone.net/Tubes/TungsramDCTable.pdf
There are some quirks with the codes. Any 3 digit codes such as 8Y0, GY0, H90......any three digit code on a tube with a 0 on the end, the 0 is dropped in the table. So keep that in mind. Also, if you study the codes carefully enough, you'll notice they used the same exact codes in a couple of different years. But it's not a problem figuring out which is the right one for your tube, though. Also, as you can see, upper and lower case do matter.
Posted: Sat May 17, 2008 11:02 am
by novosibir
Woah! That a great info, Mike!
Very helpful! Thanks a lot for it!
But I knew before, if anybody has a table, then it's you
Larry
Posted: Sat May 17, 2008 2:55 pm
by 5150loveeddie
Where would that code be? I have a "19" stamp on a little metal part under the getter or just above the mica, inside the tube, not on the class..
I see I9 in the chart but not 19????
Posted: Sat May 17, 2008 3:02 pm
by TubeGetter
It doesn't look like yours have Tungsram codes on them. Tungsram labeled Tungsrams are pretty much the only tubes that have the yellow codes on the glass, and they can wear off real easy just like everything else. Sometimes the company that relabeled the tube will have their own codes on them, and you find out the approx. dates from that. The tag numbers inside the tubes aren't date codes......likely some sort of batch number or QC number.
Posted: Sat May 17, 2008 3:10 pm
by 5150loveeddie
I see thx.., they must been weared off then...
Here is what I see on both..
Posted: Sat May 17, 2008 4:10 pm
by novosibir
You can't find an original data code on your tubes, because they're RCA labelled and not Tungsram.
The tag inside the tube doesn't say anything of importance.
Larry
Posted: Sun May 18, 2008 2:05 pm
by master keeper
in what pos did you put the tubes?
Posted: Sat May 24, 2008 7:21 am
by Roe
just got a 9t tungsram from January 1967. thanks for the table tubegetter!
also got a ecc83 labeled itt lorenz - I guess it is a siemens
Posted: Sat May 24, 2008 5:55 pm
by joshwilson3
TubeGetter and Tubetramp,
How much are you selling NOS Tungsram tubes for? I'll be getting tubes at some point for my 2203 clone that has yet to be built.
Posted: Sat May 24, 2008 10:27 pm
by 5150loveeddie
master keeper wrote:in what pos did you put the tubes?
V1
Posted: Sun May 25, 2008 12:52 pm
by master keeper
team it up with another one in V3 too!
Posted: Sat Jul 05, 2008 11:31 am
by razelfrax
I have 2 tungsrams, shortgray rca's, philips both GT B and Heerlen , Sylvanias, a mully ecc81 and a sylvania 12at7. Would my best starting point for my 50 watt clone be v1 t ram v2 Gt b mully and V3 Tram I havnt had the chance to test this with a band where things sound different but I'm guessing the tungsram cuts through better in a band setting ? Also do you guys find a tone/feel difference between the GT B mullys and the Heerlen ?
Thanks Scott
Posted: Wed Jul 09, 2008 9:16 am
by master keeper
heerlen is a bit more gritty than the mule, not quite as dark mid oriented.
Posted: Wed Jul 16, 2008 7:10 pm
by razelfrax
Thanks master keeper have any of you checked out the 12ax7 shootout clips at pp
