Re-Bias Needed With New Rectifier Tube?
Hazy
Post by Hazy » Sun May 15, 2005 8:19 pm
I got a new 5V4GA for my JTM45 clone which currently also has a 5V4GA for the rectifier tube.
Can I just swap out the new (RCA) for the old (GE)? I understand a different rectifier tube type might change the voltage and require a bias check. But, am I OK here without re-biasing?
Thanks,
Hazy
Toolbox(es) Full of Tubes
Post by Flames1950 » Mon May 16, 2005 12:34 am
As much as you'd like to hope you'll be safe, I'd take the opportunity to check that bias again.
Hazy
I Really Knew That Was The Answer
Post by Hazy » Mon May 16, 2005 8:20 am
I just didn't feel like pulling the chassis for once to put in a new non-preamp tube. On the other hand, I'll get a chance to see what happens to the circuit with the NOS RCAs.
Thanks...
Hazy
All Done...No Change
Post by Hazy » Mon May 16, 2005 10:47 pm
Still running about 425v...next project...
Guest
Post by Guest » Tue May 17, 2005 4:37 am
very interesting...ImageImageImageImageImageImageImageImageImageImageImageImageImageImageImageImageImageImageImageImageImageImageImageImageImage
