Tightest sounding EL34?
I'm playing around with my '67 circuit which includes a 330uf on V2. As expected, I'm getting a lot of boomy bass. I'm thinking that I can remedy part of the problem with a different set of power tubes. Which are the tightest? I'm guessing the 6CA7s, but what other brands? I've already got the EH 6CA7s and the JJ EL34Ls. What about The EH EL34s, I remember them sounding really good in my 1987x ... actually liked them better than the Svets. Haven't had the opportunity to test much with my 100 watters.
Gear:
'73 Super Lead
'70 Basketweave
'73 Super Lead
'70 Basketweave
- VelvetGeorge
- Site Owner
- Flames1950
- Flames1950
But as far as the tightest EL34, for new production I still like the GT E34L's (30 watts plate dissipation, so bias 'em accordingly.) Although some have claimed that the newest ones aren't as reliable; mine were bought as a quad about eight years ago, but I only was using two in a 50 watter. Bigger and cleaner than many EL34's while still haveing a lot of the characteristics of EL34's that we love.
also, reducing the filter cap value at the preamp will cut bass (not just the pramp amp one--the other ones too--but I would start there), and towards the other end, lowering the two 220ks on the power tube grids should also. If you try lowering the 220ks, be careful and make sure you do a good job since you definitely do not want to lose bias on the output tubes!
Hey George, this is my original '74 OT which has a lot more bass than my Merc.
I just figured out that I THOUGHT I had a .0022 in V2 but it was really a .022 mustard (those dang pf markings through me off). That .0022 was JUST enough to make the amp sound perfect!
Gear:
'73 Super Lead
'70 Basketweave
'73 Super Lead
'70 Basketweave
