How do you instal the bias pot??? Please somebody give me some detailed instructions. Not the wiring of it, but actually what is soldered on it. Like... arggg!
Mike
damn bias pot!
The way I got mine in was this. I set the pot into the turret holes and then held the tip of the soldering iron right at the edge of the lip at the top of the turret. I then applied a little solder onto the tip. When I did this I thought the solder would make a huge mess and spill all over the turret. Surprisingly, the solder seems to flow quite nicely down into the turret. I fed just a little bit of solder onto the iron (just a few millimeters). Then I checked that the joint was solid. I then flipped the board over and did the connections underneath with buss wire. When you're done you can check that the connections are good by measuring the resistance with a meter and turning the sweeper in the bias pot. I hope this helps.
