Sorry for the lame picture quality.. but it's dark inside a cabinet.
Anyway... are these real 8ohm Pre Rolas, or is it reissues? A local guy has these two for sale..
Are these original pre-rolas?
- Jofipe
- Scumback Speakers
- Supporting Advertiser
Re: Are these original pre-rolas?
You'll have to check the cones. If they're original they should have a white ink stamped "102 003" on the cone underneath the frame. The label,and T1220 # are correct, and the LB10 date code would be a late 69 model.
- 908ssp
What can be seen looks real but what makes them valuable is if the cones are original. So like Jim said above look for the white ink stamped number on the cone.
