After perusing about 25 pages of listed posts, I thought I'd just ask-
I'm trying to upgrade the brace in my (2) 1960B cabinets. Can anybody tell me the dimensions of their sound-post beam in a vintage Marshall bottom cab?
It's sort of like a 2x4", but as we all know, a 2x4" is actually smaller than 2"x 4"...
I've heard there is some variation in sound-post brace dimensions, from cabinet to cabinet.
The one in my '69 cab is (1 and 7/8") by (3 and 3/4").
Also, can anybody tell me the dimensions of the 'square' wooden base-plate that goes between the sound-post and the front baffle on a bottom cabinet?
The smaller one I removed from my '73-'74 bottom cab was 11-ply and exactly 9/16" thick, & (4 and 1/4") wide x (1 and 1/4") tall. The older ones look to be 'around' 4" wide x 4" tall...
How thick are the older ones, and what are the length and width dimensions of the square base-plate? Thanks!
Vintage Soundpost Dimensions
- chrisom
- bill bokey
Re: Vintage Soundpost Dimensions
I just checked a '71 1960B and it's 1 and 3/4 by 3 and 3/4. I'll check other cabs eventually.chrisom wrote: The one in my '69 cab is (1 and 7/8") by (3 and 3/4").
Still the 71 B cab :chrisom wrote: Also, can anybody tell me the dimensions of the 'square' wooden base-plate that goes between the sound-post and the front baffle on a bottom cabinet?
3 and 3/4 square, 5/8 thick
- chrisom
Thanks, Bill Bokey!
YOU ROCK!
YOU ROCK!
Yes, what starts off as 4"x2" rough sawn and is then machine is planed down, how far depends on the guy on the planer.
As it is not size critical it is not cut and measured further - just used as it comes off the pile!
I used a piece of off-the-shelf 2x6 Douglas fir (actual size 1 3/4" x 5 3/4" or thereabout). I cut the two sides down to give it the square cornered look and net 4" wide. I did some fancy footwork on the end that contacts the baffle around the horizontal brace...a regular work of art for the obsessive at heart . I would have preferred pine but oh well..
As a side note this was for a 900 series 1960A cab. I added a vertical brace, a larger post and new check grill cloth. (I also converted it to a 2x12 - it can easily be changed back to 4x12). I cut a piece of pine 1" x 4" (3/4" x 3 3/4") to length for the vert. brace. Using a contour gauge I notched out to accommodate the existing screwed and glued horizontal brace and cut a 16 degree slant in the upper portion. At this point it went a little south on me in that I didn't realize how flexible the baffle is at the horizontal brace (hinge!). My 16 degree angle didn't seem quite right so I futzed with that a bit (should have left it alone!) then glued with pl plus and screwed the brace from the outside. After installing new cloth I put her back together and it came out ok but the grill cloth did relax a tiny bit. I have not yet tried a spray bottle w/water and a hair dryer. All this said so someone else might avoid the mistake.
Pics? Seems Photobucket has broke the internet.
