Might work ok, but IMO too close to #3 - I'd move it more east, no matter whether south-east or nord-east, only keep space to the PT!bulatovic wrote:is this better? Or should i move point 4 more to the "north-west" of the chassis (oriented by this photo)?
You can't solder the back of PEC's w/o special chemics, because they're VA (stainless steel), but the additional nuts will ground it properly.bulatovic wrote:The other question is on potentiometer case grounding. I'm planning on going with PEC pots, but since they have long shafts, i have to put spacers - i'm not gonna install plastic spacers, but use additional nuts. Is that going to provide proper case grounding or should i try to connect a bus along the back of the pots and ground it?
There are a lot of rules and I could write a book with about 50 pages or even more only about this, but don't expect this from me in a forum - I have a full time business w/ 70-90 hours a week runningbulatovic wrote:Is there any rule on which cables should or should not be close to each other along the chassis (not counting on cables from the board to the sockets)? Grid leads as short as possible and to have nice distance between them and the plate wires - well just as shown in the George's manual.
To stabilize each to the other on its long way - ok! But no electrical benefit, cos they contain DCbulatovic wrote:What about the Choke wires and OT CT. I was thinking of twisting all 3 of them?
Run it close along the chassis (shielding effect) to the front chassis' edge and then therein along - not through free air.bulatovic wrote:Any suggestions on the layout of the wire going to the potentiometers (apart from the presence pot wire going as far away as possible from the other tone stack wires)?
We're waitingbulatovic wrote:EDIT: OH MAN, WILL I HAVE TO TREAT YOU WITH SOME HIGH QUALITY CLIPS WHEN I GET MY AMP DONE - AS A THANK YOU FOR BEARING ALL OF MY BORING QUESTIONS AND PROVIDING HELP
Larry
