Schematic of JTM45 Custom Build
arledgsc
Re: Schematic of JTM45 Custom Build
Post by arledgsc » Mon Feb 04, 2013 9:39 am
This schematic is great but I have one question that perhaps someone can clarify. As I follow the Metroamp instructions/schematic it shows the 27K NFB resistor is connected to the 16 ohm tap of the impedance switch. However, the posted schematic shows the NFB resistor connected to the 8 ohm tap on the impedance switch. Which way is correct??
27K/16 is traditional. My schematic is "custom" and based upon experimentation, taste,and record of my JTM45 build. The lower the NFB resistor the greater the negative feedback which, in turn, lowers distortion and increases frequency response at the expense of reducing gain. For me, 27K was too much feedback and felt like the amp opened up with less NFB. But start with the traditional NFB and work from there if you desire.
Here's a MetroAmp build schematic. I used it as a starting point for my amp. The schematic is for my records and MetroAmp is not affiliated with the contents or correctness. So don't blame George for any errors. Scott
http://www.keepandshare.com/doc/1782399 ... 8-66k?da=y
Metro JTM45, Metro 50W Lead, JTM50 Black Flag, and Ceriatone 18W TMB
Scumback M55/M75, Ceriatone C-lator
