B+ voltage
tfrost33
Post by tfrost33 » Mon Sep 17, 2007 10:11 pm
OK... hmmmm :? So I followed the trouble shooting instructions to the letter. I can find absolutely no problems with either the Output Transformer nor the Power Transformer. All the tests come out fine. Neither of the transformers gets hot or hums or smokes. Maybe the smell is just my imagination since Bob came over and couldn't smell anything.
So here is the deal... I decided to re-test the whole unit as if I had just finished with the assembly. I pulled all the tubes and began the testing phase from square one. All was fine with my readings clocking in around 10% or less (higher and lower) than the chart provided in the instruction cd. All up until the point where I have to measure DC Volts at pin 5 off V4 & V5. I should be getting around a -45 VDC correct!?!? But I get nothing, Zero, Ziltch! I am testing pin 5 to ground on this step correct? It says to check the bias circuit? How? Also I had installed swamp resistors in series with pins 5 to help calm the standby switch squeal. Could that be an issue, I used green blue red, which I think is 56K resistor.
This is gettin crazy :shock: :shock:
Thanks guys
http://www.soundclick.com/tfrost" onclick="window.open(this.href);return false;
http://www.myspace.com/lookerwy" onclick="window.open(this.href);return false;
http://www.myspace.com/borzayamusic" onclick="window.open(this.href);return false;
ScottW
Post by ScottW » Mon Sep 17, 2007 10:19 pm
Green, blue, red is 5.6K which is what you want.
OK, you're on to something. Having no bias voltage at pin 5 will cause the tubes to red-plate and die, so continuing to use those tubes will probably cause fuses to pop like crazy.
Yeah, you test stuff in the bias circuit with your meter set to DC volts and with one lead connected to ground. Here's where a good photo would help!
tfrost33
Post by tfrost33 » Mon Sep 17, 2007 10:20 pm
Oh yes, one more thing. The amp was on for about 20 minutes or so while did all the testing... And not one fuse blew the entire time. The only tubes not in it at this point are the KT66's. But I still do not have the negative 45 VDC needed on pin 5 of V4 and V5.
Just thought I should add that just in case.
ScottW
Post by ScottW » Mon Sep 17, 2007 10:23 pm
Sounds like the tubes have blown for lack of bias voltage. So even when you get the bias circuit fixed, a bad tube could pop your fuse right away.
tfrost33
Post by tfrost33 » Mon Sep 17, 2007 10:42 pm
10-4 Thanks a bunch Scott, you have been a great help. I will keep on it and figure out whats going on with the bias circuit and post on it Wednesday or Thursday. Starting to get late now and I should have been doing things other than this all day, but you know how it can get :lol: I have a lot of work I need to take care of the next couple of days but at least I, well... WE narrowed it down to this. I will try and get Bob to come over and take some photo's too.
Thanks again!
uiovbged332
Re: B+ voltage
Post by uiovbged332 » Wed Jul 06, 2022 12:29 pm
Lebron 16
Nike Factory Outlet Store Online
Jordans Sneakers
Nike Running Shoes For Women
Air Force Ones
NMD R1
Pandora
Fjallraven Kanken Backpack
Yeezys
Adidas Yeezy
New Nike Air Max 2019
Nike Shoes
Nike Store
Nike Zoom Pegasus 35
Yeezy
Asics Shoes
Nike Shoes For Men Basketball
Louboutin Shoes
Christian Louboutin Sale
Nike Factory
Nike Shoes
Nike Basketball Shoes
Pandora Earrings
Christian Louboutin Heels
Moncler Outlet
Nike Air Force
Jordan 13 Retro
Air Jordan Retro
Nike Shoes For Men
Nike Sneakers For Women
Pandora
Nike Factory Outlet
Christian Louboutin shoes
Nike Shoes
Nike Factory Store Online
Yeezy 500 Black
Yeezy
Nike Air Max 98
Nike Air Max 270
Red Bottoms
Louboutin Heels
Nike Outlet Store
Nike Air Max
Christian Louboutin Shoes
Vans
Pandora
Nike React
Adidas Sneakers For Men
Nike Outlet Online
Adidas Ultra Boost
Pandora Necklace
Jordan 11 Blue
Yeezy Boost 350
Ferragamo
Golden Goose Shoes
Air Force 1 Mid
Nike Outlet
Jordan Retro
Pandora Bracelet
Nike KD
Nike Shoes Outlet
Adidas Stan Smith
Lebron 16 Shoes
Nike Clearance Store
Nike Air Max
Air Jordan Shoes
Air Max 720
Jordan Sneakers
Cheap Nike Shoes
Air Max 720
Ferragamo Shoes
Air Max 98
Nike Free
Christian Louboutin Shoes Outlet
Pandora Rings
Kids Jordan Shoes
Pandora Charms
Yeezy Boost
Pandora Jewelry Rings
Nike Outlet Store
Nike Cortez
Nike Shoes
Pandora Charms
Pandora Charms
Louboutin Shoes
Pandora Outlet
Nike Sneaker
Jordan Retro
Ultra Boost
Lebron Shoes
Kyrie Irving Shoes
Louboutin
Nike Air Mag
Pandora Charms
Nike Shoes
Nike Huarache Men
Ferragamo Belts
Nike Shoes
Nike Black Friday 2020
Valentino Sneakers
Nike Outlet Store
Nike Outlet Online
Fjallraven Kanken
Pandora Jewelry Official Site USA
Air Force 1
Nike Lebron 17
Nike Clearance
Christian Louboutin UK
Pandora Bracelets
Pandora Bracelets
Christian Louboutin Outlet
Red Bottom
Jordan 11
Nike Outlet
Adidas NMD
Nike Shox
Nike Shoes
New Nike 2019
Kyrie Shoes
New Nike Shoes 2019
Lebron Shoes
Nike Presto
Nike Sneakers Outlet
Mens Nike Shoes
Nike Air Zoom Pulse
Air Max 95
Nike Free Run
Yeezy 550
Adidas Yeezy
Pandora UK
Adidas Yeezy
