16 mfd cap on the board
George, I've noticed that your kit amp for the JTM 45 contains a large blue 16uf cap which is wired on the board, as was done on the original Marshall JTM 45s I've checked out. But I've also noticed that the same cap is missing from the RI PTP board and it is missing from the board from my Mojo JTM 45 combo amp as well. Do I need this cap or is that capacitance handled elswhere in the circuit, such as from one of my 2 32X32uf filter caps? Is my amp technically still a JTM 45 without that board mounted cap? Thanks!
RickS
- Flames1950
George used the 16uF board cap to be authentic. But the can mounted on the side of his JTM45 kit is a dual 16/16 with one side left unused (the only 16uF-rated can available for use.) The RI and the MoJo use the other half of the cap can instead of the board-mounted 16uF cap. The Marshall RI has this can mounted above the circuit board instead of one the side of the chassis; I don't know where the MoJo cap is mounted exactly.
The JTM45 circuit requires four filtering caps total, so two dual section cap cans can cover everything; George just likes to be accurate as possible......
Thanks Flames, my Mojo amp has both of it's dual 32uf filter caps mounted on the inside near the OT. Now I'm wondering if I should figure out which of them is handling the capacitance normally done by the 16uf cap on the board, and have my amp guy replace it with a dual 16uf cap and rewire. Would that make much of a difference soundwise? As it is the sound is pretty hellaciously good. If I ever do another JTM45 or Plexi amp I wouldn't hesitate to go with a Metro kit. Although the Mojo guys sell good stuff the tech support (2 years ago anyhow) was pretty much non existant and at the time Metro wasn't doing JTM45 kits. Otherwise I can see that the job of building it from a Metro kit would have been so much smoother and faster.
- Flames1950
