1st off I have never built a amp but I can solder. so I would like to make the normal ch (high and low) inputs to sound as bright as the high ch because I'm using a aby switch and am using the high ch for my gain sounds and the low input on the normal ch with vol at half for my clean but would like it to be brighter. so I also want to tame the brightness on the high ch! so any info would be great. I've heard of cutting the bright cap on the high ch but I don't know how and if I could increase the gain a touch that would be swell!
I just picked up this metro 45 that was on the bay.
thanx and sorry for the long post but any help would be great
need jtm45 normal ch to be as bright as high ch?
- axeman
Re: need jtm45 normal ch to be as bright as high ch?
add a 250pf to the Normal channel
dumb q but any schematic or how do I do it? or any pics I can look at?axeman wrote:add a 250pf to the Normal channel
- axeman
Were do you live?
