Weird voltages..got some issues. Could use some eyes please?
Big Mike
Post by Big Mike » Thu Feb 21, 2013 6:43 pm
anyone eyeball anything that looks wrong?
Working the startup test...
4.7 volts before the recto tube.
only 33V on v1 pin 1 so i Stopped.
Thanks for any help! Much appreciated.
http://i103.photobucket.com/albums/m141 ... 8333a5.jpg" onclick="window.open(this.href);return false;
http://i103.photobucket.com/albums/m141 ... e29d6c.jpg" onclick="window.open(this.href);return false;
http://i103.photobucket.com/albums/m141 ... 78b371.jpg" onclick="window.open(this.href);return false;
Metroamp kit JMP50 - CM OT
Marshall 2550 Jubilee
Scumback Speakers
Re: Weird voltages..got some issues. Could use some eyes ple
Post by neikeel » Fri Feb 22, 2013 11:28 am
Sorry Mike need better pics with better light of the rectifier socket, PT wiring and switches.
What I can see even magged up looks ok......
Big Mike
Post by Big Mike » Fri Feb 22, 2013 1:22 pm
thanks I'll get some better ones.
weird stuff.
4.7 volts between 2&8 of recto
120V at the wall
610 Volts on standbye off...on it drops to 406
Nothing on pin 5 of V4 and V5 (Should be -45DC)
heaters are good.
when I went (farther than I should have) yesterday with preamp tubes in, ( no power) only got 33V on pin 1 of V1.
Scumback Speakers
Big Mike
Post by Big Mike » Fri Feb 22, 2013 1:34 pm
Recto tube readings for pins 4 and 6
standbye off. tube in.
Pin 6 347VDC
Pin 4 422 VDC
Standbye on
pin 6 36VDC
pin 4 50 VDC
Scumback Speakers
Big Mike
Post by Big Mike » Tue Feb 26, 2013 12:52 am
Foiled by a bad HT fuse.
Everything dropped right in line...though the recto was a bit under 5V.
Sounds great though.
Scumback Speakers
