Output transformer question
Ukko75
Post by Ukko75 » Thu Apr 23, 2015 4:11 am
Hi!
I have output transformer that has 6,6k primary impedance and i´am planning to puild JTM 45 amp. The question is should i use KT66 or EL34 tubes with this transformer?
ivan H
Re: Output transformer question
Post by ivan H » Thu Apr 23, 2015 9:21 pm
Hi, u should use the KT66 ideally, tho people do use EL34's. If u plan on using EL34's u could mismatch the speaker load to the impedance selector, ie; use an 8 ohm speaker load with the selector set to 16 ohms, this way the EL34's would see a plate to plate load impedance of 3k3. Hope this helps. Cheers
Ukko75
Post by Ukko75 » Fri Apr 24, 2015 12:08 am
Thanks for the information!
I will order pair of KT66:s.
