KT66 JTM45 / JMP50 hybrid?
Re: KT66 JTM45 / JMP50 hybrid?
Post by neikeel » Thu Dec 24, 2015 9:52 am
ezietsman wrote:...and here's the amp inside its shell :-)
Looks like a near perfect set up- when are you getting a red 4x12? :whistle:
ezietsman
Post by ezietsman » Sat Dec 26, 2015 3:59 am
Erm, I don't know if I would. They're a bit big. If I bash around this one enough I may recover it in red but the tolex on it is pretty tough so it may take a good few years :)
ezietsman
Post by ezietsman » Thu Dec 31, 2015 7:35 am
I recorded another clip, with my Tokai Breezysound (50s spec Tele) this time.
Amp settings:
Presence: 5
Bass: 2
Middle: 8
Treble: 8
Volume 1: 11 (plugged into high input)
Volume 2: 2 (jumpered into high input)
Amp was set to use the Bass Tonestack, Solid State rectifier and high negative feedback
https://soundcloud.com/ewald-zietsman/e ... with-tokai
My JJ GZ34 has given up already. I think the plates are loose inside, I can hear rattling when I shake the tube. I blow the mains fuse when I use it. Working on getting some NOS Raytheons from a local guy, else I may just get a Weber WZ34.
Post by neikeel » Thu Dec 31, 2015 11:17 am
That big 1k in your B+ line will be stressing your rectifier like heck!
ezietsman
Post by ezietsman » Fri Jan 01, 2016 6:45 am
neikeel wrote:That big 1k in your B+ line will be stressing your rectifier like heck!
Why is this?
ezietsman
Post by ezietsman » Wed Feb 03, 2016 5:48 am
Triode is sending me a replacement choke, free of charge. Soon, this plexi will be complete :D
