8 or 16 ohm loads
8 or 16 ohm loads
So this may have been discussed before I am sure.
But I have a question here regarding the use of attenuators and the ohm load prefered.
Whats the consensus
8tap to 8ohm att to 16ohm cab?
Or 8tap to 16ohm att to 16ohm cab??
Any two cents here or insight all welcome.
Whats the consensus
- efraser68
Re: 8 or 16 ohm loads
DC I am 8tap to 16ohm att to 16ohm cab
Me too. Always sounded right to me with either of my amps.
- JimiJames
same here
- Jeremy1283
Im at a 4ohm tap. 16 ohm load: 16 ohm cab
- echoplexi1974
Do you hear a tone difference when setting the impedance of the amp lower than the attenuator/cabinet?
Yeah but remember, You have a 100 watt OPT Trans with a 1.7K primary and you have 2 tubes pulled. So properly matched, you would run the amp at 8 ohms into a 16 ohm cab for two tubes. So your amp with two tubes pulled at 4 ohms is the same as 4 tubes being on 8 ohms into a 16 ohm load.Jeremy1283 wrote:Im at a 4ohm tap. 16 ohm load: 16 ohm cab
I tried two tubes, 4 into 16. Yikes it was bright and bottomless for me. 8-16 sounded like it was more right on my amp. Even with 4 tubes it sounded better than 4-16. 8-16 load re-amped has it best as well when in that route.
Bottom gets more correct, hights cut a bit different, total sound compresses a bit and the amp fries a little harder.
- Jeremy1283
That is my experience so far.. BRIGHT! lol
I just putt the hfb on the ohm selector so i can adjust it on the fly. Thanks dc for the advice
That's about exactly as I would expect. With 2 tubes, 4 ohm amp to 16 ohm load should be the same as 4 tubes, 8 ohm amp to 16 ohm load though.
I guess I'm a moron, but I run my amp at 16 ohms, into the attenuator, into a 16 ohm cabinet. Please forgive my ignorance, but why would one intentionally mismatch the load?
I originally did that with a Bluesbreaker, because I'd read that's what EC did, but then I read it was potentially harmful, so I matched it.
Thanks,
Brad
Thanks,
Brad
Model citizen...Zero discipline
I don't get that. My amps are always mismatched (by one step only) and I would argue that the tone is not brighter. The amp behaves a little differently with SAG and feel and the lows are held together a little better with punctuality. Harmful? I seriously doubt that. I'm near 5 years with it this way and recently bought a tube tester. Tubes tested outstanding but I also run at 90VAC which I would also argue, actually prolong tubes. If they died today, I would be more than pleased. Hell, I'd be happy with this even if I only got a year out of them.
Everything Jnew said and then some. Even MesaBoogie has a tutorial stating the mismatch can have tonal benefits. 8 into 16 is just a heavier load than 8-8. Maybe works the transformer and parts more.
Think of it as a gear reduction. Like when you pedal your mountain bike. 8-16 is like trying to climb a hill with big long hard pushes on the pedal. In a smaller gear you will have all kinds of power to climb the hill but have to pedal way faster to stay movin. 8-4 would be like pedeling so fast your legs burn up and fall off and we know thats the wrong kinda mismatch. There is hardly no resistance and tour amp has nothing to push gainst and it hyper speeds itself into complete burnout. You aren't as hot with big long pushes on a bike pedal but pedaling as fast as possible you will wear out in no time. This 8-4 WILL make magic smoke.
Somehow though I am prefering 16-16 suddenly now but am getting less sag effect than 8-16 but my mids and body seem fuller at 16-16. I may revert back to 8-16 maybe.
- Carbia
I like the amps with matched impedance.
16 on 16 is the best to me
