SoZo Product Release
NEWS RELEASE
FOR IMMEDIATE RELEASE
January 2018
NEW! - SoZoTM SILVER MICA CAPACITORS
CE Distribution and SoZoTM Capacitors are pleased to announce the immediate release of the new SoZo Silver Mica capacitors. This new capacitor line offers superior musicality and linearity and are modeled after the well sought out vintage picofarad capacitors of yesteryear. These custom designed capacitors have the same electrical characteristics and sound of the ones from the past.
The characteristics of SoZo silver micas are clear, smooth, vocal, clean and linear top end. SoZo caps are smooth without forward treble, i.e., the top end voicing does not add the treble harshness like standard silver mica caps tend to do. Also, standard silver mica caps often have excess energy and ringing in the out-of-band audio frequencies which creates a disconnected strident metallic high end in any amplifier circuit. The SoZo design eliminates this excess energy and ringing in the out-of-band audio frequencies; therefore, with the SoZo caps, the treble does not detach from the fundamental note and does not create sibilance like modern components do.
In every audition performed, the new SoZo silver mica capacitors were the preferred hi-frequency component in every audio application - equalizers, microphones, or guitar amplifiers - due to their superior musicality and linearity. These SoZo caps will delight OEM, D.I.Y., restoration, and hobbyist builders worldwide.
CE Distribution is the exclusive worldwide distributer for SoZo Capacitors and is the leader in wholesale distribution of parts for guitars and amplifiers. CE Distribution is known for quality, availability, and excellent customer service. Whether you are building, repairing electronic gear or reselling parts, CE Distribution is your partner in meeting your needs and offering same day shipping.
To order from CE Distribution, you must be a pre-registered wholesale business; music stores, repair shops and OEMs can contact CE Distribution at (480)755-4712 or visit www.cedist.com. For retail sales, visit www.amplifiedparts.com.
January 2018
http://www.sozocapacitors.com" onclick="window.open(this.href);return false;
- bill bokey
Re: SoZo Product Release
Buying some asap
Why cant you match the size and look?
Seems like a marketing ploy to me.
Sozo Mustards had some sizes mismatches too.
These are not cheep so get it right if these are supposed to be expensive tone replicas.
Sounds like pure BS to me. Any electrical component that does not have a publicly available data sheet is suspect.
They did post specs on another forum.
Specs completely match CDE 1000v mica series.
All SOZO did was call up CDE and ask them to make 250p and 500p micas.
TOTALLY 1000% wrong...
enjoy..
enjoy..
If SOZO new anything about recreating the old caps of yesteryear they would know 500p was not the common value in Marshall amps.
560P or 556p in JTM45s was the value used.
But WAIT! CDE 1000v all ready makes a 560p!
Why not just slap your logo on the CDE 560!
About to try these out, though I do wish they could make the 560p. Makes such a difference.
