Page 2 of 4
Posted: Tue Nov 15, 2005 8:20 pm
by mightymike1
Ralle's is 50x2, ****** account of EVH's amp says there's a single 32 there.
Posted: Tue Nov 15, 2005 9:43 pm
by 5150loveeddie
Don't forget Ralle uses a JB pick up, that is really not the same as what Eddy used........Ralle adapted and fine tune his amp to make it sound like VH..........JJtubes? Not Sylviana, etc....etc....so those little details got adjusted by increasing/decreasing capacitance among other things etc...etc....Ralle has great hears to do that...........
Posted: Fri Nov 18, 2005 6:26 pm
by mightymike
It's almost as if Ralle was experimenting with the Values in ******'s description of EVH's amp, but had to add the .68uf to the presence to make up for the reissues. The end goal tone being the same, just 2 different paths to get there. So if you have RI Greenbacks try Ralle spec, but if you have the real deal 12h30 Pre Rola or Heritage go with Cerrems 1.1k rks too will add to your gain.
Posted: Fri Nov 18, 2005 7:04 pm
by 5150loveeddie
Yep!!!!!!!!
Posted: Wed Feb 15, 2006 8:05 pm
by rockstah
i must try 1.1k - one thing i notice going from 820 to 2.7k - the 820 seems like it has more gain but at the same time im not sure if thats cause compared to the 2.7k its thinner and high endier( if thats a word
) the 2.7k is a fatter sound.
Mark
Posted: Wed Feb 15, 2006 10:22 pm
by Flames1950
Hmm, my ears told me the opposite, that the 820 had a warmer sound, since the bypass cap was not as effective with the lower value resistor, despite the higher frequency shelf of the cap/resistor combo. The bigger the cathode resistor, the more the signal would rather go through the cap if it can, so your bypass cap's gain boost is more apparent........another of those balancing act things we run up against.
Posted: Wed Feb 15, 2006 10:26 pm
by rockstah
Flames1950 wrote:Hmm, my ears told me the opposite, that the 820 had a warmer sound, since the bypass cap was not as effective with the lower value resistor, despite the higher frequency shelf of the cap/resistor combo. The bigger the cathode resistor, the more the signal would rather go through the cap if it can, so your bypass cap's gain boost is more apparent........another of those balancing act things we run up against.
i beg to differ!
shall i post a clip?
changing v1b from 820 to 2.7k
- 820 will have more distortion in the higher freqs- thinner overall
2.7 will be thicker -not as much distortion - alitte warmer / fatter sounding
Mark
Posted: Wed Feb 15, 2006 10:36 pm
by 5150loveeddie
Hey Mark your only rebiasing your pre amp tube with different resistor value there, from 820ohms to 1.1k you'll get a smoother result....try it and less us know.........
Posted: Wed Feb 15, 2006 10:39 pm
by rockstah
5150loveeddie wrote:Hey Mark your only rebiasing your pre amp tube with different resistor value there, from 820ohms to 1.1k you'll get a smoother result....try it and less us know.........
i plan on trying the 1.1k very soon
with my findings as of lately i even wonder what it would sound like with 1.1k on v1b and a 2.7k on v2a.
i also want to experiemnt with 820 on v1b and .022 and then 2.7k on v1b with .0022
Posted: Tue Jun 06, 2006 1:02 pm
by gnugear
I added a switch to toggle between 820ohm and 2.7k. 2.7k definitely had more gain.
Posted: Tue Jun 06, 2006 1:32 pm
by rockstah
gnugear wrote:I added a switch to toggle between 820ohm and 2.7k. 2.7k definitely had more gain.
i saw 2.7k as having a fatter overall sound to the note - to my ear 820 appeared to be more distortion but not as fat sounding - i prefer 2.7k
Posted: Wed Jun 07, 2006 6:44 am
by mightymike
rockstah wrote:5150loveeddie wrote:Hey Mark your only rebiasing your pre amp tube with different resistor value there, from 820ohms to 1.1k you'll get a smoother result....try it and less us know.........
I used some 1.1ks and like this setup
V1----> 330uf/1.1k, .68uf/2.7k
V2------>330uf/1.1k
.02 after the first Stage
Slope /Treb 56k/250
Mixer 470k/500pf
I'd like to try some 1k, or 1.1k cement resisters in those spots.
[/quote]
Posted: Wed Jun 07, 2006 8:39 am
by Bainzy
http://www.metroamp.com/forum/viewtopic.php?t=6385
Here's my observations of the resistor - I think this is way more important than any of the above components you guys mentioned (ie. filtering, cathode resistors).
Posted: Thu Jun 08, 2006 10:27 am
by 45auto
is it rediculous to put variable resistors in positions on the preamp tubes for fine adjustment? i used to do that back in the late 70's.
Posted: Thu Jun 08, 2006 11:12 am
by pongo316
45auto wrote:is it rediculous to put variable resistors in positions on the preamp tubes for fine adjustment? i used to do that back in the late 70's.
Was thinking the same thing. tweek away until i find the right value.
