whoa sounds close to evh
- rockstah
same as last specs listed except now ---> 4ohm tap
http://www.markabrahamian.com/rockstah_ ... medley.mp3
Mark
Mark
- 5150loveeddie
BIG IMPROUVEMENT there Mark
Hey you swaped the .1ufs for .022uf?
- rockstah
same as above with 100pf "fizzy" cap and dual 16 in preamp
http://www.markabrahamian.com/rockstah_ ... edley2.mp3
Mark
Mark
- rockstah
same as above but now NO .68 cap installed onto v2a
http://www.markabrahamian.com/rockstah_ ... edley3.mp3
Mark
Mark
- rockstah
the pickup i have been using in my les paul is the shredder from jim wagner. it measures 16.7k - here is a clip with everything the same as last but now a jim wagner darkburst pickup ( 8.5k) interesting. this brings to my attention that when dialing it is important to think about which pickup you will be using as you can see the sound changes quite a bit. i think my ears are shot at this point and the playing is not as up to par - taking a break for a day or so - if i can
tell me what you think.
http://www.markabrahamian.com/rockstah_ ... edley4.mp3
Mark
Mark
- Flames1950
LEAVE THE DARKBURST IN THERE!!!!!!
Sounded so good I could taste it from here!! The low end has gotten that loose EVH feel without the gritty furriness it had a few clips ago and the mids and top end are much improved. Overall the fuzziness I was hearing a few days ago is vastly improved now -- YOU'RE SO DAMN CLOSE........
Give your ears the rest and come back to this clip in a day, and see if you don't love it. I don't even remember which amp spec you're on, and it doesn't matter, it sounds great!!
mark
the 8.5 p/u sounds much better. On the legendary tones site under the duncan custom evh p/u they said the key to it is the 8.5K and the alnico ll magnets. I think your darkburst definately is better. I know you have probably said but I'm confused by all the posts, what speakers are u using?
- rockstah
Re: mark
i hear ya there - i'm using 1976 25watt rola 16ohm at 75Hzmedicsteve wrote:the 8.5 p/u sounds much better. On the legendary tones site under the duncan custom evh p/u they said the key to it is the 8.5K and the alnico ll magnets. I think your darkburst definately is better. I know you have probably said but I'm confused by all the posts, what speakers are u using?
- saborthw
Mark
I have a Matched Pair of the Duncan EVH PUPs in a USA Wolfgang,
Duncan calls this pickup model 79 or Evenly Voiced Harmonics.
My neck is 7.93 ohms & bridge is 9.1 ohms these pickups are really versitile and sound great for everything, flat out these pickups rock.
Regards
Scott
Regards
Scott
Gear
59 LP, 1956 Custom Shop Strat, 50 wattt Mesa Stiletto Ace 1X12 combo , Protools OO2 R. 12XXX 68 Series Metro Plexi. 1960 BHW 4X12
