Post
by plexified » Fri Feb 17, 2017 2:46 am
Hey gang,
as this all sounds so killer, would it be out of line to admit Ed was not out of bounds by saying it was a stock spec head? cause these variances , although quite the variety are all within a stock head spec?
As I mentioned I used these specs too and they kill. My PI was a .022 in the end as opposed to a .1 I had tried as well. The main thing to note with my stock 12 series was that it remained VERY consistant in terms of tone. Maybe the newer builds would be more responsive to the variants. Mine was always in the zone with all the variants. It did kind of blow me away. Being my application was original small power trans and original small OT . My only variant was a small 27k presence resistor on the neg tap.
To be clear , the 330/1.1k on VI and VII with a original 25 watt single cab at 110v and Sylvania 6cA7 tubes was spot on. Twin 100 power dual 32 and dual 16 pre. 27k presence on the neg and .022 on the PI. 47 pie ceramic cap and boom. Does not matter if I drop it on the variac lower like 80 or 90. It tells me that the PT spec and OT spec are very dominant. And this head has had a wide range of all of the above inserted and it all sounds TOTALLY in the zone.
This being said , in a new build , pay attention to the 'range' of tweaking to at least know you are in the zone and these specs need to be tweaked to your liking. I think when you go to the next level like with a re amp or even using the variac in your output speaker loop that these are tools that sound fantastic and are definitely a part of the sound. I think its safe to say we have decoded that they were used and are tools. The re amp is to get more volume and damn it adds more character for sure. And to just use the variac in the speaker loop does give you the chance to turn it down AND get more character.
This is ground breaking stuff and be sure to acknowledge it on its own merit , because Ralle is showing his tone is always killer at every step of the way and these ranges are totally relevant. I think back to Rgalpin and his same re amp and tweaking and its the same killer tone and playing! I say win , win , win , we have the best tones as a result of everyone here just singing and killing it like we could not have imagined. Jnew and Strat78 and Tx and VHjunkie and on and on , you guys are killing it man! We have to celebrate such a vast achievement of tone and knowledge and don't forget twisty! WOW gents , WOW! Thanks for all of it , it totally ROCKS!
