rgalpin wrote:
i believe this is a great key to getting the correct delay effect and you describe it perfectly. however, i have 2 questions about your assumptions.
1. if he is using a marshall as a power amp he would get the ducking effect heard in the ISO clips even if he places that echo after the first amp. i've done it and it works just like what you hear in the ISO tracks. if you put it in front of the first amp the ducking effect is more dramatic and in my opinion TOO dramatic.
The second marshall is used for it's clean power. It's not overdeiven, or if it is, only a slight bit to where it isnt noticeable. You are correct, if the second marshall were overdriven, and the echoplexes before it, the echoplexes would duck... BUT, the already overdriven, compressed guitar from the first marshall would render this ducking effect useless due to the complete lack of dynamics from the overdriven guitar/effects/1st marshall. The key to getting a good ducked echo is running a dynamic signal(from a guitar) into an echo, THEN compressing/overdriving it.
rgalpin wrote: 2. the univox was used for that 350-ish ms delay that ed always uses? is there a reason why you assume it is not the echoplex?
I think it's the univox because Eddie said he used the univox to get the echo dive at the end of eruption. We know Eddie ran the phase 90 before the first marshall. And if you listen to the echo dive at the end of eruption. At the end when it stops descending and is just looping, the loop is phasing. In order for the loop to be phasing, the echo HAS TO BE before the phaser. So if eddie said that the echo dive is done with the univox echo, the echo before the 1st marshall should be the Univox echo.
