EP-PRE revisited
Good Guest
Re: EP-PRE revisited
Post by Good Guest » Sun Oct 16, 2011 5:57 pm
The 24 volt power supply is key also...not 9 or 18 but 24 especially with all the attenuatin going on with the series of resistive networks going on after the fet...some say they are acting as phase shift networks...but they are just simple attenuation networks. The output is 180 degrees out of phase to the input of the fet anyways ...which is a natural operation of the fet in common source configuration like in the ep3.
Xplorer
Post by Xplorer » Sun Oct 16, 2011 6:04 pm
my echoplex has 22 volts, not 24, coming into R4. after R4, it's 13 volts. So .. am i right if i say that it's just a matter of adjusting R4 value to have the right voltage after R4, coming into the fet ? no need for 24 volts or 15 volts or 18 volts ... if only 13 volts are required, is that right or am i missing something ?
oh ... perhaps minus 22 or 24 volts are required on the ground ... mh ...
Good Guest
Post by Good Guest » Sun Oct 16, 2011 7:11 pm
Yeah that's right 22vdc....the voltage drop to 13 0r 14 is from the fet and R4....just dumping any fet in there and placing a resistor and adjusting it too 13 is not right ..you need a scope..or you can use your ear...or you'll end up clipping a top or bottom of your signal instead of enjoying the headroom...and if you were to send a hot signal to the fet you would want it to clip symetrically , or asymetrically? ..so just adgusting to 13 volts won't work ..you need the exact fet and exact 22k and exact 22vdvc to do it that way. Now if waveforms for the ep3 were available showing the clipping characteristics , that would be differant and fet circuits could be designed to match at least those characteristics.
The same goes if you used any old fet and placed a 22k there ..depending on the fet you may not even get a signal. Once you change that 22k you also change the impedance and how it reacts to certain frequencies also... now you know why people don't bother ..they just get the darn thing to pass a signal and call it a day and sell it... they don't even know what circuit Eddie used.
Buy the way it clips assymetrically when overdriven ..just like a smooth fuzz unit. :wink:
Xplorer
Post by Xplorer » Sun Oct 16, 2011 7:39 pm
:wink: it starts to be tough science for me !
it's a new tis58 in there ... 13 volts isn't right ? i didn't hear my echoplex clipping, i don't understand. i know it has some background noise on the echo at higher level but for the rest it sounds ok so .. ( ? )
what voltage should that be in there ? mmh , lopoking at an old paper from mike battle, it says D : 8,2 volts , S : 1,58 volts and G : -0,03 volts ( "varies" )
symetric and asymetric, clipping, i'm not educated enough to understand this, i'm sorry.
that's also why i want to build a separate preamp, 100 % correct, so i'll compare it with my echoplex without touching it yet. cause if i want to improve something and iit goes less good, i won't be very satisfied. so i'm going there little by little, first : the preamp.
leadguy
Post by leadguy » Sun Oct 16, 2011 10:15 pm
Well, all transistors and tubes have to be DC biased to allow AC signal swing operation to function properly.
The AC signal swings around the DC bias and if the DC bias is too high or too low for a particular tube or transistor or if the AC signal is too large and swings too much around the DC bias then the tube or transistor clips the AC signal producing a square wave like output and that is distortion.
Biasing a particular Jfet can be done by using it's spec sheet.
The Echoplex Jfet is biased for clean operation but can be overloaded into clipping by a large AC signal input just like anything really.
For how to do the output, look at how the output is for this jFet and there is the answer http://www.till.com/articles/GuitarPreamp/" onclick="window.open(this.href);return false;
Ed's EP-3's are around the 255xx serial number range which is also the EP-3 with a compressor board range.
How do I know this?
By Ed's EP-3 logos and also by knowing that he had these EP-3 logos in May 1977 and knowing the serial numbers of the wider EP-3 logos which Ed had.
Good Guest
Post by Good Guest » Sun Oct 16, 2011 10:41 pm
Well said Leadguy
From the Tillman write up
"I should point out that FETs in general suffer from a serious lack of manufacturing consistancy. The FET VGS and IDSS, the parameters that determine the bias point, can be anywhere over a 5-to-1 range and still be within spec. That's pretty awful, but such is life. It's an engineering accomplishment to design a circuit that can function exactly the same over a wide variation of component parameters. But I can't guarantee that in this situation; there's not enough supply voltage headroom. "
The fet in the ep3 suffers from the same problems except , because of it's high operating voltage suppy has an advantage over the tillman, when it comes to headroom...So if you hear of a manufacturer " handpicking fets" at least you might be getting some value. Hand picking is expensive tho when it comes to rare and valuable fets ....
At least with the tillman you got lots of info and tech support of the simple circuit...I'd switch the 2.2 k to 3.3k and adgust the drain resistor by ear till I found a fet that works as close to the 22k value as that determines the output impedance , actually anything in between 10k and 22k would be OK and call it a day ..and you end up with a great 9 volt boost with a EVH flavor. Once those parameters are met then you can change the input to copy the ep3's and or the output cap..
:rock:
Xplorer
Post by Xplorer » Sun Oct 16, 2011 10:58 pm
interesting ! do you know how to measure a fet ? i recently learned how to guess wich pin is G with a multimeter, but i really don't know how to choose a fet, as it's so different from one to another one. and that's maybe why my ep3 has this higher voltage on D.
i feel frustrated not to understand how to use a scope, and knowing what to do then. i don't have any anyway. that could be useful to make my ep3 even better, dead silent.
Good Guest
Post by Good Guest » Sun Oct 16, 2011 11:36 pm
Xplorer wrote:interesting ! do you know how to measure a fet ? i recently learned how to guess wich pin is G with a multimeter, but i really don't know how to choose a fet, as it's so different from one to another one. and that's maybe why my ep3 has this higher voltage on D.
You would probably benifet from building the tillman...obtaining some j201's that are readily available and pinouts etc...and hooking it all up like an ep3 use a 9 volt battery supply.....THEN hook up a drain resistor like a 100k pot and adjust till you hear signal and play around with that...record the operating resistance ...if it isn't beween 10k and 22k insert another j201...till you find one that works at those drain resistance levels...you'll get a good handle from that...your ears will tell you lots ..you don't really need a scope unless your going to be a bigtime marketer of ep3 copy pedals with standards that should be met.
You don't really need a a scope to measure a fet ...rg keen used to have a nice rig setup using a multimeter and battery that would measure some parameters ...do an internet search for it..jeez after doing all this you'll be all primed for building yer own phase 90 with 4 matched fets.. :thumbsup:
Xplorer
Post by Xplorer » Mon Oct 17, 2011 12:08 am
ha ha !
yeah, a pot for the drain resistor sounds nice. but i'll have several 2n5457, good for the ep3, and i have a few tis58 left.
yes, i saw something from rg keen but it was to measure some germanium transistors. but i'll take a look again, he might say something about the fets.
to my ears my echoplex sounds perfect, i don't want to change it, even if it's out of specs if i understand.
I just want to make an exact ep3 preamp clone, not a tillman ( for now ), and compare it. and i just want to improve it by removing some noise :
i think that i'm gonna disconnect the head board, and disconnect the motor circuit, to see if it does anything good ( but being naïve and not well educated, i hope that it's not gonna change all the voltages on the rest ! ) and i'll take a look at this Dc filtering board, mine seems to be a variant, perhaps improved i don't know. i should try it with stock specs. what do you think ?
all i want is to be able to increase the volume pot at max without hearing an undesired background noise like a vacuum, o i'll know the at lower levels, the echo will have a much better quality.
the t70 nortronics board .... well i don't know what it does, and if it can bring noise.
the transformer : someone seem to have screwed something into it a bit, so i should perhaps replace it.
But sooner, i'll have a look at how my two echoplex will sound in chain, when i get a chance to find another 230v - 120v converter. and by the way i should perhaps simply have a new transformer that accepts directly 230 volts.. and have a voltage regulator or something ...
or i should experiment all this on the second echoplex without touching this one yet. but does anybody has some spare echoplex pieces ? i'd need a bridge and a sliding chassis for the write/erase head combo, cause this one came with 6 heads in line, fixed.
in the end i think that i'll can compare the preamp clone, and both echoplex and i'll tell you, if i can do it one day ...
and i'll mod my ep3 to have both preamp versions, with some switchs ...
i already have a cool feature i invented by accidnt, that allows three positions : signal and echo - SOS - and echo + sos playing the signal and what was "echoed".
a speed variation for the motor could be cool ... very long echoes ... special effects ... tape flanging with the other ep3 etc ...
uiovbged332
Post by uiovbged332 » Wed Jul 06, 2022 10:43 am
Air Max 720
Ferragamo Outlet
Red Bottom Heels
Nike Air Max 97
Kyrie Shoes
Yeezy
Jordan Sneakers
Pandora Jewelry
Nike Clearance
Adidas Sneakers
Yeezy Shoes
Christian Louboutin
Air Jordan Shoes
Yeezy 500 Utility Black
Yeezy Boost
Air Force 1 High
Nike Store Online
Nike Sneakers Outlet
Louboutin Outlet
Nike KD Shoes
Pandora Necklace Women
Nike Air Max 98
Ferragamo Belt
Nike Shoes For Men
Basketball Shoes
New Nike
Christian Louboutin Shoes
Nike Sneakers
Nike Sneakers
Air Max 2019
Nike Air Max 720
Nike Outlet Store
Pandora Charms
Kyrie Irving Shoes
Air Jordan Shoes
Adidas NMD
Vans
Nike Air Max 95 Essential
Womens Nike Shoes
Nike Sneakers
Lebron James Shoes
Pandora
Christian Louboutin shoes
Lebron 16
Nike Outlet Store
Nike Air Force Ones
Pandora Jewelry Official Site
Pandora Canada
Christian Louboutin
Nike Factory
Jordan Kids
Nike Store
Red Bottom Shoes For Women
Jordan 11 Blue
Air Jordans
New Shoes
Nike Zoom Winflo 5
Adidas Ultra Boost
Christian Louboutin Outlet
Nike Air Max 98
Nike Running Shoes For Women
Fjallraven Kanken
New Nike Shoes
Yeezy Sneakers
Pandora Earrings
Nike Outlet Store
Pandora Jewelry
Adidas NMD
Nike Factory Outlet
Fjallraven Kanken Backpack
Yeezy Boost 350
Golden Goose
Jordan Retro 11
Nike Shoes Outlet Online Store
Jordan Retro
Pandora Bracelet
Lebron 16
Nike Outlet Store
Louboutin Outlet
Nike Factory Outlet Store Online
Nike Clearance Store
Nike Black Friday Sales
Yeezy Boost 350
Nike Shoes For Women
Red Bottom Shoes
Jordan Retro 13
Air Jordan Shoes
Pandora UK
Pandora Canada
Adidas Ultra Boost Men
Lebron 16
Nike Air Zoom
Nike Running Shoes For Men
Nike Air Force 1 Men
Nike Clearance
Yeezy
Nike Factory
Air Max 720
Nike Air Force
Pandora Rings
Asics Shoes Outlet
Nike Factory
Nike Shoes
Nike Outlet Online
Nike Factory
Ferragamo Shoes
Pandora
Nike Outlet
Moncler UK
Nike Shoes For Men Basketball
Nike Air More Uptempo
Cheap Yeezys
Nike Free
Nike Presto
Adidas Yeezy
Pandora Bracelets
Pandora Charms
Nike Air Max 270 Womens
Red Bottoms Louboutin
Nike Huarache Women
Mens Nike Shoes
Nike Outlet Store
Valentino Shoes
Stan Smith Adidas Sneakers
Nike Mags
Nike Free Run
Pandora Charms
Nike Cortez Women
Louboutin Shoes
Mens Nike Shoes
Christian Louboutin
Nike Shox For Men
Pandora Charms
Nike Outlet Store
Cheap Nikes
Nike Lebron 17 Low
uiovbged332
Post by uiovbged332 » Wed Jul 06, 2022 12:34 pm
Asics Shoes For Women
Adidas Trainers
Adidas Women's Shoes
Yeezy
Jordan 1 Dior
NMD
Pandora Jewelry
Pandora Charms
Salvatore Ferragamo
Nike Men's Shoes
Air Jordan 1 Low
Jordan 1's
Adidas Official Site
Nike Canada
Asics Sneakers
Moncler Jacket
Pandora Charms
Adidas Yeezy
Nike Canada Online Shopping
Air Jordan 1 Retro
Nike Store
Pandora Jewelry Outlet
Moncler Coats
Nike Canada Online
Adidas Shoes Canada
Goyard Handbags
Shoes Nike
Pandora Bracelets
Pandora Jewelry
Nike Women Shoes
Pandora Official Site
Pandora
Pandora Rings
Nike Canada
Balenciaga Triple S Sneakers
Adidas Canada
Nike Air Jordans 1
Ferragamo Shoes
Pandora Charms Outlet
Cheap Adidas Shoes
Pandora Bracelet
Moncler Jackets Outlet
Moncler Jacket For Women
Puma Shoes
Nike Shoes
Wholesale Jordan
Cheap Moncler
Yeezy Boost 350 V2
Pandora Rings
Pandora Charms
Air Jordan 1 Low
Asics
Pandora Jewelry
Adidas Canada Online
Moncler Outlet
Ferragamo
Jordan 1 Retro
Nike
Pandora Jewelry
Nike Shoes Men
Balenciaga Sneakers
Asics Gel-Kayano
Jordans 1
Jordan 1 Low
Nike Canada Online
Balenciaga
Pandora Jewelry
Nike Outlet
Pandora Bracelet Charms
Adidas Shoes
Pandora Jewelry
Nike Store
Nike Sneakers For Men
Nike Shoes
Nike Sneakers Women
Pandora Jewelry
Pandora Jewelry
Moncler Sale
Women Nike Shoes
Pandora Charms
Moncler Sale
Jordan Retro 1
Asics Outlet
Nike Outlet Store
Balenciaga Shoes
Adidas Shoes Men
Pandora Charms
Pandora Outlet
Pandora Bracelets Charms
Balenciaga Sneakers
Balenciaga Sneakers
Air Jordan One
Ferragamo Belt Men
Pandora
Asics Running Shoes Women
Pandora Charms
Wholesale Jordan Shoes
Pandora Jewelry Store
Ferragamo Belts
Pandora
Moncler Coat
Air Jordan 1 Low
Nike Outlet
Pandora Outlet Online
Asics Outlet Store Online
Nike Running Shoes
Pandora
Adidas
Basketball Shoes
Balenciaga Shoes
Pandora Charms
Air Max 720
Adidas Sale
Jordan 1 High
Nike Shoes For Men
Pandora
Pandora Jewelry
Pandora Charms
Nike Outlet
Cheap Jordan Shoes For Men
Nike Canada Online
Adidas Sneakers Men
Pandora Jewelry
Pandora Charms
Pandora Charms
Adidas Outlet Store
Charms Pandora
Jewelry Pandora
Goyard Bag
Jordans Wholesale Suppliers
Nike UK
Nike Snkrs Canada
Pandora Charms
Adidas Running Shoes For Men
Yeezy Shoes
uiovbged332
Post by uiovbged332 » Wed Jul 06, 2022 10:13 pm
Jordan 24
Nike Slippers
Jordan 17
Nike Huarache
Nike Running Shoes
Air Jordan 33
Retro 12
Nike Air Jordan 1
Louboutin Shoes
Wholesale Nike Shoes
Air Jordan 13 Retro
Nike Free
Nike Womens Shoes
Nike Metcon
Adidas Shoes
Pandora Rings
NBA Jerseys
Fjallraven Kanken Official Site
Jordan 33
Adidas China
Jordan 12
Nike Wholesale
Nike Air Max
Nike Lunarlon
Wholesale Adidas Shoes
NBA Jerseys
Nike Shoes
Nike Outlet Store
Wholesale Adidas Sneakers
Nike SB Dunk
Nike Sneakers
NFL Shop Canada
Nikes
Nike Cyber Monday
Jordan 6s
Jordan Retros
Wholesale Nike Shoes China
NHL Store
Jordan 11 Low
Nike Shoes Sale
Michael Jordan Shoes
Jordan AJ 1
Nike Shoes
Red Bottom Shoes Christian Louboutin
Cheap Nike Shoes From China
Pandora Charms
Air Jordan 26
Jordan 2
Jordan 28
Jordan 31
New Nike Shoes
Nike Outlet
Air Force 1
Nike Zoom Fly
Jordans 25
Nike Zoom
Air Force Ones Nike
Adidas Shoes Canada
Jordan 5 What The
Nike Air Force 1 Women
Wholesale Nike Clothing
Nike Wholesale
Nike Outlet
Cheap Jerseys Wholesale
MLB Shop
Adidas Yeezy
Air Max 720 Flyknit
Jordan 15
Nike Air Force 1
Nike Air Jordan
Cheap Jordans Free Shipping Wholesale
Jordan 14
Cheap Nike Shoes
Cheap Jordans
Nike Canada
Yeezy Boost 350 V2
Pandora Charms
Nike Roshe
Jordans 13
Jordans 18
Nike x Off White
Nike Shoes
Jordans 21
Nike Sneakers For Women
Jordan Retro 4
Nike Foamposites
Official Nike Outlet Online Store
Nike Air Force 1
Jordan 20
Lebron James Shoes
Pandora Jewelry
Air Max 270
Jordans 23
Nike Huarache
Air Max
Jordans 27
Wholesale Cheap Jordans
Adidas Outlet
Jordan 11
Wholesale Jerseys China
Nike Outlet Online
Jordan 11
Huaraches
Jordan 30
Adidas NMD
Wholesale Jordans
Baby Jordans
Nike Cortez
Nike Air Max 2019
Wholesale Jordans
Adidas Yeezy Boost 350 V2
Cheap Jordan Shoes
Jordan Shoes
Nike
Jordan 19
Jordans 34
Nike 270
Jordans 35
Cheap Jordan Shoes
New Jordans
Nike Epic React
Air Jordan 33
Nike Air Force 1
Dior Jordans
Pandora Ring
Jordans For Kids
Nike Air Force 1 Low
Nike Jordan 1 Mid
Air Jordan 11 Retro
Air Jordan 32
Adidas Store
Jordan Retro 12
Nike Clearance
Nike Foamposite
Jordan Retro
Nike Wholesale
Jordan 16
Nike Shoes For Mens
Jordan 29
NHL Jerseys
Nike Shoes
Jordan 22
Pandora Jewelry 70% off Clearance
Nike Shoes
Nike Roshe
Pandora Jewelry
Cheap Shoes Wholesale
