REFERENCES FOR RALLE's VH/AMP/SPECS/GEAR/SET-UP, etc.....
5150loveeddie
Post by 5150loveeddie » Thu Nov 03, 2005 3:16 pm
The info is all over the forums now, so any links, or a nice resume of his amp/gear/diagram/set up/pics, etc... right here so we don't have to dig in hundred of pages on information!!!!
No partial info here please!!! Only the "FULL" and "EXACT" stuff please
We could place this as a sticky also maybe?
Merci Beaucoup!!!
Bainzy
Post by Bainzy » Fri Nov 04, 2005 5:32 pm
Circuit Board Parts List
Resistors:
820ohm (2)
2.7k ohm
68k ohm (4)
100k ohm (4)
470k ohm (2)
56k ohm
1M ohm (2)
470 ohm
82k ohm
10k ohm 1/2w (1)
10k ohm 2w (3)
47k ohm 2w (2)
8.2k ohm 2w
15k ohm
27k ohm 2w
Capacitors:
100pf
250pf
500pf
.022uF (5)
.1uF (3)
.68uF (1)
10uF (2)
330uF (2)
20uF 450v axial filter capacitor (2)
100uF 450v/500v axial filter capacitor (2)
50uFx50uF 450v/500v axial filter capacitor (2) - jumpered to make 100uF
Diodes
5 x 1N4007 diode
also, on the presence pot there's a .68uF cap on the middle lug and a 4.7k ohm resistor on the ground lug (the lug that doesn't have the purple wire connected to it)
theres likely to be mistakes in this as I've done some of it from memory, if there is PM me so I can edit it
Shred Guitar
Billy Batz
Post by Billy Batz » Fri Nov 04, 2005 6:14 pm
Just to quickly reitterate since this is an EVH Thread. Bainzy your values seem to have some Ralle values throwen in
Resistors:
820ohm (2) (Two accounts say these drifted to just over 1k (1.1k). Ive used 1k here before (on cerrums suggestion) and it definitely sounds smoother but its very sublte.
2.7k ohm
68k ohm (4)
100k ohm (4)
470k ohm (2)
56k ohm
1M ohm (2)
470 ohm
82k ohm
10k ohm 1/2w (1)
10k ohm 2w (3)
47k ohm 2w (2)
8.2k ohm 2w
15k ohm
27k ohm 2w
Capacitors:
100pf
250pf
500pf
.022uF (5)
.1uF (3)
.68uF (1)
10uF (2)
330uF (2)
This is a Ralle value. EVHs supposedly was 16. Their close enough.
50uFx50uF 450v/500v axial filter capacitor (2) - jumpered to make 100uFIf this is the screens filter then this also is a Ralle value. The 'alleged evh value was 32+32 in series or 16u. The can on the chassis was supposed to be 32u. Ralle has his at 100 IIRC
Diodes
5 x 1N4007 diode
Again a ralle value. I may be wrong but I dont think this particular type of presence control was around in 68.
[/i][/quote]
5150loveeddie
Post by 5150loveeddie » Fri Nov 04, 2005 10:10 pm
Ralle's hook up:
I'm playing a plexi superlead from -67 or -68 ( I think it's a -68 ). The guitar is a home made strat with a heavyash body and a two peace maple neck. I'm using a Seymore Duncan JB J, and a Floyd Rose whammy. The set up is as follows:
The head ( set at 8 ohm ) into a dummyload.
Into a Powerbrake ( set at 8 ohm ).
Into a 8 ohm cab loaded with four 25 w celestion greeinies.
Now, the thing is that I have the dummyload in serie between the amp and Power brake, so I get a total load of 16 ohm, while the amp is set at 8 ohm.
I could just get a 16 ohm dummy and be done with that, but I need an attenuator to be able to play at home, and not scare away the people in the clubs. And the Power Brake has to be set at 8 ohm since my cab is at 8 ohm. If I were to set the PB at 16 ohm ( wich is possible ), I have to get a 16 ohm cab. So... to get this load of 16 ohm, and keep my PB in the chain, this is the only way to do it.
Guest
Post by Guest » Sun Nov 06, 2005 3:15 pm
Does anyone know what these Ralle specs sound like WITHOUT the high output JB pickup since Eddie used a low output PAF? I know a jb drives those older amps more than a paf. I would love to hear a clip with Eddies style of pickup to see if it still has that same gain and tone.
Bainzy
Post by Bainzy » Sun Nov 06, 2005 3:28 pm
Billy Batz wrote:Just to quickly reitterate since this is an EVH Thread. Bainzy your values seem to have some Ralle values throwen in
cheers Dan, that's right I posted the Ralle spec - it's pretty similar to the EVH one. That mountain of NOS caps I told you about had 1 resistor in one of the bags, it turned out to be a NOS Carbon Comp one at 1k (measured closer to 1.1k), so I tried it in V2 instead of the 820ohm MO one and it really improved the sound like you said. It sounded more smoother and musical, and it was surprisingly noticeable for 1 resistor change. I want to put in a lot more CC's but I need to trade or sell some of the caps I bought first as I just can't afford to buy anything right now.
Shred Guitar
Billy Batz
Post by Billy Batz » Sun Nov 06, 2005 4:21 pm
I remmeber seeing Cerrum post that on PP saying he used one of those cement resistors and it sounded smoother and creamier. I had 2 extra 1k5W xicons so I tried it. I think Id just prefer using CCs.
5150loveeddie
Post by 5150loveeddie » Sun Nov 06, 2005 4:57 pm
Billy Batz wrote:I remmeber seeing Cerrum post that on PP saying he used one of those cement resistors and it sounded smoother and creamier. I had 2 extra 1k5W xicons so I tried it. I think Id just prefer using CCs.
Billy what was that cement resistor thing ****** suggested again? I didn't get that one....
Billy Batz
Post by Billy Batz » Sun Nov 06, 2005 5:18 pm
He mentioned using those 1k xicon 5W cement resistors for cathode resistors in place of the 820 ohms.
5150loveeddie
Post by 5150loveeddie » Sun Nov 06, 2005 6:07 pm
Oh ok, you tried it and you didn't see any real differences?
Billy Batz
Post by Billy Batz » Sun Nov 06, 2005 6:55 pm
No I did think it sounded smoother actually. But just a touch. What I meant was CCs instead of cements.
clarkydaz
Post by clarkydaz » Mon Nov 07, 2005 8:55 am
i have them 1K wirewound blocks on the cathodes. whilst tinkering they are the only things that have remained unchanged in my amps so far
mightymike
Post by mightymike » Sun Nov 13, 2005 7:22 pm
I updated my Ralle Spec layout and it is complete now. Hope this helps.
It's an animation that you can watch in explorer or any browser.
http://mightymike1.home.comcast.net/ima ... lespec.gif
or if you like a higher quaity (not as blurry) single images of the top and bottom, here's the single files used to make the above animation.
Turn 90 degree before printing, and they fit to a page.
Ralle Top single bitmap image 5.56mb
http://mightymike1.home.comcast.net/images/Ralle-a.bmp
Ralle under board single bitmap image 5.56mb
http://mightymike1.home.comcast.net/images/Ralle-b.bmp
Bainzy
Post by Bainzy » Tue Nov 15, 2005 6:13 pm
Dan, you say the can on top for the EVH amp was 32uF - is that single or double 32uF?
Anyone know what Ralle has there?
Shred Guitar
rockstah
Post by rockstah » Tue Nov 15, 2005 6:31 pm
Bainzy wrote:Dan, you say the can on top for the EVH amp was 32uF - is that single or double 32uF?
thought it was 50x50 there like in mikes images
