Power transformer sag ?
jnew
Re: Power transformer sag ?
Post by jnew » Sat Mar 30, 2013 3:25 pm
So the stock JTM-45 Re-issue Pwr Trannie is probably a piece of shit then. It worked great with the 2204 front end but I'm not getting anywhere real pleasing in the plexi mode. I am using a MM OPT Trannie and it seems to be quite nice. 8)
Post by neikeel » Sat Mar 30, 2013 5:28 pm
jnew wrote:So the stock JTM-45 Re-issue Pwr Trannie is probably a piece of shit then. It worked great with the 2204 front end but I'm not getting anywhere real pleasing in the plexi mode. I am using a MM OPT Trannie and it seems to be quite nice. 8)
Big jump from asking what PT does a 50watter use to saying the Marshall RI PT is a POS!!! :roll:
The re-issue PT gives lower voltages than an original JTM45 PT (RS type 1->RS type 2->Drake 1202-55) all of which give around 450v. They all sag a little under heavy load, assisted by the tube rectifier. The 50watt plexi PT was usually a Drake 1202-118 which could be tube rectified (like my 67 JTM50) or diode rectified this gives around 420-430v depending on the quality of the recifier tube or if you are using diodes. The tube rectifier with this PT sounds very good to my ears and gives enough sag but does not crap out. Nothing wrong with the diode set ups either.
Later amps with standup 1202-169PT (and coincidentally the 45RI have lower voltages and typically run 400v or less) the RI has better quality steel than the old ones is wound on plastic bobbin to higher specs so sags less, which maybe why it sounds better in 2204 modern mode. I ran my RI with the MM Axion 16 OT for a while until I transformed the amp with a Metro Heyboer -103 clone :rock:
jnew
Post by jnew » Sat Mar 30, 2013 7:47 pm
Well hmm, let me see here. I was asking because I was giving thought to possibly changing out power transformers. The amp used to be a JTM-45 but I threw out the PCB stuff and re did it all to plexi 50 watt 68 ish spec. But since my last post, I'm going to agree with you whole heartedly. I plugged the amp straight to the cab, put everything on 10 and it is fu@#$ng great. Loud as piss but the tone is outstanding so no issues with the power transformer. You are also correct with the naturally low plate voltages. Mine was at 395, straight from the wall. I thing with the variac at 95VAC, it's like 310VDC. And yes, it does sag nicely but holds it together quite well. More experimenting to come but I'm realizing that my problem is somewhere in my slave setup. Not the amp. 8)
jnew
Post by jnew » Sun Mar 31, 2013 1:19 am
In fact, I might even try the tube rectifier again just for some comparison. It's been many years but I do recall it wasn't bad at all. 8)
uiovbged332
Post by uiovbged332 » Wed Jul 06, 2022 3:03 pm
Pandora Outlet
Balenciaga Triple S
Nike Outlet Store
Nike Sneakers For Women
Yeezy Boost 350 V2
Best Nike Running Shoes
Pandora Outlet
Puma Shoes
Ferragamo Belts
Balenciaga Shoes Women
NMD
Pandora Jewelry
Pandora Outlet
Pandora Jewelry Outlet
Pandora Outlet
Nike Shoes For Women
Jordan 1 Low
Adidas Trainers Sale
Nike Outlet Online
Pandora Jewellery
Nike Outlet Store Online Shopping
Asics Outlet
Adidas Canada
Dior Jordan 1
Nike Shoes Canada
Asics Gel-Kayano
Pandora Rings
Nike Canada
Nike Store
Pandora Bracelets
Pandora Jewelry
Pandora Jewellery
Adidas Clearance Sale
Pandora Charm
Moncler Jackets Women
Balenciaga Shoes
Nike Mens Shoes
Pandora Jewelry
Adidas Official Site
Wholesale Jordan Shoes
Adidas Running Shoes For Men
Pandora Bracelets
Shoes Ferragamo
Pandora Charms
Adidas
Pandora Charms
Pandora Bracelets
Adidas Store
Nike Store
Pandora Charms
Wholesale Jordan
Pandora Charms Sale Clearance
Asics Sneakers For Women
Ferragamo Shoes
Pandora Outlet
Wholesale Jordans China
Asics Outlet Online
Moncler Jackets Sale
Pandora Jewelry Official Site
Ferragamo Belt
Air Jordan 1 Low
Moncler Jackets Outlet
Yeezy
Wholesale Jordan Shoes From China
Pandora Charms
Nike Shoes Men
Air Jordan 1 High
Pandora
Jordan 1 Retro
Jordan One
Pandora Jewelry
Nike Outlet Canada
Nike UK
Nike Men Shoes
Pandora
Nike Shoes
Nike Shoes
Adidas Sneakers
Nike Women Shoes
Cheap Moncler Coats
Adidas Shoes Men
Yeezy Shoes
Pandora Charms Outlet
Adidas Shoes Canada
Cheap Nike Shoes
Pandora
Moncler
Cheap Adidas Shoes
New Nike Shoes
Jordan 1s
Pandora Outlet Online
Air Jordans 1
Nike Canada
Moncler Coat
Pandora Jewelry
Adidas Shoes
Goyard Handbags
Pandora Jewelry
Salvatore Ferragamo
Pandora Bracelet
Balenciaga
Goyard Bags
Air Jordan 1
Pandora Bracelet Charms
Balenciaga
Moncler Outlet
Asics Running Shoes
Adidas Yeezy
Adidas Canada
Pandora
Pandora Jewelry
Basketball Shoes
Pandora
Air Jordan 1 Retro High Og
Pandora Jewelry
Asics Outlet
Nike Air Jordan 1
Nike Sneakers Men
Pandora
Moncler Jacket
Pandora Charms
Jordan 1
Nike Canada Online
Pandora Charms
Pandora Jewelry
Nike Shoes Outlet
Asics Shoes For Women
Balenciaga Sneakers Sale
Pandora Black Friday
Balenciaga
Air Max 720
Pandora Charms
Nike Sneakers
Jordan 1 Retro
Pandora Rings
Pandora Jewelry Store
New Nike Shoes
Pandora Jewelry
Outlet Moncler
Adidas Shoes Women
Pandora
