Lets talk about 45/100 chassis and panels
kewl.......since i don't need any voltage switch ....and tell me ...i stamped my custom chassis speaker holes taking for a template one of your jtm45 white rear panel...are the 45/100 rear panel speaker holes at the same place than those on the simple 45 ? i aligned the 45 panel like this on the larger 45/100 chassis to cut my speaker holes in the chassis :
I------'''''''''''''''''''''''I
well you probably know what i mean ...
- VelvetGeorge
- Site Owner
which PT would be historically correct in this early el34 amp? would it be the same PT as in the kt66 amps or would it be the later tranny?Flames1950 wrote:Yes, the very earliest EL34 amps did still have the seven-cap/six-diode board just like the KT66 JTM45/100's. Roger's Amp Archives site has pics of at least one of these amps available.Roe wrote:so the boards is correct for the first el34 amp as well?
That's what I plan to build with at least one of the chassis I plan to snag......
- Flames1950
As far as I know the PT, or at least the first PT specific for EL's instead of KT's would be the 1203-80. The OT would be the 1202-132.Roe wrote: which PT would be historically correct in this early el34 amp? would it be the same PT as in the kt66 amps or would it be the later tranny?
This is the information Greg Germino offers with his '67 "Fillmore:"
http://www.germinoamps.com/fillmore100.htm
And a nice shot of the rectifier/filter cap board there as well.
- VelvetGeorge
- Site Owner
- Flames1950
Like anything Marshall the transitions were not that organized. Here's some 45/100 shots with EL34's, the 1204-43 PT, and the 119 OT which came before the 132:thousandshirts wrote:As far as I know the PT, or at least the first PT specific for EL's instead of KT's would be the 1203-80. The OT would be the 1202-132.Roe wrote: which PT would be historically correct in this early el34 amp? would it be the same PT as in the kt66 amps or would it be the later tranny?
http://www.amparchives.com/album/Marsha ... index.html
Here's one with an eight cap board even, but the older single rectifier arrangement:
- out of focus
