My official JTM45 kit build thread. Pics & CLIPS ADDED
- mushmouth
Wow it's quiet in here lately...
Step 13 is complete -- Wiring the front side of the chassis to the board.
Let me know if anything I've done with the routing here is going to cause me noise problems. I tried to isolate everything from each other, but if that's wrong and certain things SHOULD be forced to cross or come in contact with each other that I haven't already done, let me know. I've tried to provide enough pics to see what's going on...
Pics:
Pics:
- franc
- wdelaney72
- mushmouth
Thanks guys, I couldn't have done this so quickly without the help of the people on this board! This is beyond addictive. I'm bummed I'm coming to the end of the build...
I've posted a question in the JTM45 board about resistor choices here:
http://forum.metroamp.com/viewtopic.php?t=13290
I want to solve where I should be using the Allen Bradley Carbon Comps for vintage accuracy as opposed the beige carbon film variety. I posted the board layout there, if someone could circle which resistors they'd replace with Allen Bradley's I'd be all set. I'm planning to do the board tonight!
- mushmouth
Several nights straight of staying up until 2 or 2:30 am on worknights and over the weekend to work on this amp finally hit me yesterday. I got home from work at 6pm, passed out on the couch, and didn't wake up until 7 am this morning! I should be getting to work on the circuit board tonight. I'm going to get everything onto the board, take a pic and post it here before doing any soldering. Just want to make sure it's right.
Thanks all...
Thanks all...
- mushmouth
Ok. I have all the components in place on the board, not soldered. I've replaced everything recommended with Allen Bradley's, with the exception of a few I'm missing. I'll have George send me what I need. Those are temporarily filled with Carbon Film resistors. It's also missing the bias resistor you add in a later step.
Here is what was recommended in another thread, regarding which to swap out for the ABs:
Then I spoke with George who also recommended the 820 and the 100 on the 2nd tube cathodes, in addition to that 27K over on the right. I swapped the 820 and 27k.
Lemme know if you spot anything out of place. The orange stripe on 3 of the AB 68k's looks brownish, so I measured them. All of my AB 68k's come in at about 80k, except one comes in at 72k. Odd ducks, those.
Pics:
Pics:
- toner
1/2 watt AB's are fine for those V2 cathode positions (820 and 100k). The gray 2 watts are only used there for their lead length.mushmouth wrote:The ABs in the positions where they're replacing the grey 2 watters... Aren't those little ABs the wrong watt rating to be using in those positions??
Great job on the board. Looks very nice!
- toner
First of all, ALWAYS trust George before me!mushmouth wrote:So using your advice and George's advice on the ABs, I'm only missing one 100k and one 270 AB, correct? Everything look correct otherwise?
Yes, those two resistors will complete it. I checked everything on your board and it's all correct (unless I missed something, but I don't think so).
- mushmouth
What's the deal with the different color of orange on those 68k ABs? Is that pretty normal? I'm not thrilled about the 80+k readings on those, but I'm guessing with break-in they'll settle down?toner wrote:First of all, ALWAYS trust George before me!mushmouth wrote:So using your advice and George's advice on the ABs, I'm only missing one 100k and one 270 AB, correct? Everything look correct otherwise?
- toner
I'm sure their age and how they were stored may affect the coloring. A few of mine had slightly different color brightness too.mushmouth wrote:What's the deal with the different color of orange on those 68k ABs? Is that pretty normal? I'm not thrilled about the 80+k readings on those, but I'm guessing with break-in they'll settle down?
Have you confirmed that your meter is accurate? Measure the CF's and see if they read high also. Just a thought.
I think CC's have a tendency to drift UP in value but I don't have first-hand experience with this. Ask George, Flames or Larry to confirm this.
- mushmouth
Yeah, the 68K Carbon Fibers I have all measure at about 67.5...toner wrote:I'm sure their age and how they were stored may affect the coloring. A few of mine had slightly different color brightness too.mushmouth wrote:What's the deal with the different color of orange on those 68k ABs? Is that pretty normal? I'm not thrilled about the 80+k readings on those, but I'm guessing with break-in they'll settle down?
