How about a high gain amp kit?
Product sales, customer service, and announcements.
Brentsp
Post by Brentsp » Mon Jan 16, 2006 2:30 pm
Bainzy wrote:To be honest I'm not quite sure about V2 - the amps changed so much (for the better) since that clip. I think at the time I had a DPDT switch that came free with my pickups, and I was using half of it to select different V2 bypass caps (up = 820ohm + 330uF, middle = 820ohm, down = 820ohm + .68uF). Unfortunately one night while working on the Bainzy mod the miniswitch broke. It was likely to be 330uF or .68uF as I used those most of the time, but that cathode change doesn't have as much affect as you might think - it's fairly subtle in the grand scheme of things, but it's a nice little switch to have. It definately wasn't 250uF on V2, I've never tried that. In fact, I've never even tried 250uF on V1 :shock:
If your amp has a decent OT, caps and tubes you will get a much better sound from the Bainzy mod than is on those clips - in those clips I still had the crappy stock OT and tubes, and was running Mallory 150's (I couldn't even afford Sozo Mustard+ caps back then, but now I have those throughout). I'll record some clips of it with different V0 cathodes soon - I'll try 10k/0.022uF and 2.7k/.68uF again and compare. My recording gear is slightly better too so should be a bit better suited.
I'll have to try a .022uf also but I imagine its going to be to bright and shrill. I'm using a .1uf on the first cathode now and I had to fatten up the rest of the circuit some. Adding a 100pf to .001uf (1000pf) to the first plate resistor helps take the shrillness out.
scottosan
Post by scottosan » Mon Jan 16, 2006 3:25 pm
Could i get a copy of the mod please?
scottosan@sbcglobal.net
Thanks,
Scott
Bainzy
Post by Bainzy » Mon Jan 16, 2006 3:27 pm
scottosan wrote:Could i get a copy of the mod please?
Thanks,
Scott
Sure thing Scott, I'll send it now
EDIT: sent!
Shred Guitar
bmf5150
Post by bmf5150 » Mon Jan 16, 2006 3:39 pm
Bainzy,thanks!
Bainzy
Post by Bainzy » Mon Jan 16, 2006 3:41 pm
No probs
Shred Guitar
bmf5150
Post by bmf5150 » Mon Jan 16, 2006 3:50 pm
just sent you an email!
Bainzy
Post by Bainzy » Mon Jan 16, 2006 3:51 pm
reply sent!
Shred Guitar
kram
Post by kram » Mon Jan 16, 2006 9:32 pm
Could I get a copy of this emailed too?
Cheers
Bainzy
Post by Bainzy » Wed Jan 18, 2006 6:35 am
I'll send it when I get home later today, it's only on my home computer.
Shred Guitar
Country Boy Shane
Post by Country Boy Shane » Wed Jan 18, 2006 12:49 pm
Or possibly a JCM800 kit? That could be the last great Marshall. I don't think i've played a good one past that point. The DSL and TSL sound okay, but don't come close to a blaring 800!
Just Feel it MAN! -Shane Gorski "Country Boy Shane"
www.flickr.com/photos/shanegorski
kram
Post by kram » Wed Jan 18, 2006 4:28 pm
Bainzy wrote:I'll send it when I get home later today, it's only on my home computer.
Thanks for that Bainzy.
tonejones
Post by tonejones » Wed Jan 18, 2006 9:27 pm
Bainzy,
Could I also please have a copy of this schematic????
Thanks in advance.......
Bainzy
Post by Bainzy » Thu Jan 19, 2006 12:20 pm
No probs 8)
tonejones wrote:Bainzy,
PM me your email address and I'll send it to that.
Shred Guitar
joshwilson3
Post by joshwilson3 » Thu Jan 19, 2006 2:24 pm
Does anyone have any idea if this would work on a Master Volume? I would like to add an extra tube (with on/off switch) to a Master Volume and still use the pre-amp volume to adjust the overal distortion.
I guess I wouldn't really need it as I get plenty of distortion with my Boss RGE-10, but I think it would be cool to be able to turn on an extra gain stage.
Bainzy
Post by Bainzy » Thu Jan 19, 2006 3:05 pm
There's no reason why it shouldn't work with a Master Volume. I think the best amp to get for doing this mod is a 2205 or 2210, as you can take out the stock circuit board and put a 2203/4 board in. That will leave you with a spare preamp tube (as those 2205/2210's had 4 preamp tubes), so there's no drilling to be done.
Shred Guitar
