help with Wiring Mercury O45RS-L
Posted: Fri Mar 29, 2019 4:28 am
Hi all,
i just build my first jtm45 clone (tubeampdoctor) so i am a bit of a rookie.
link for layout from my build
https://www.tubeampdoctor.com/images/ar ... .04.14.pdf
i ordered the Mercury O45RS-L but i need some help with the wiring its a bit difficult for me.
heres the link with the wiring diagram
https://www.mercurymagnetics.com/2018/w ... 45RS-L.pdf
is this correct:
primary
Green white on pin 3 V4
Green on pin 3 V5
Centertap to fuseholder
Secondary for 8 Ohm
Brown White Black connected with each other
Red and blue together: to positive speaker load to speaker input jack
Green: negative speaker load. to speaker input jack
is this correct:
primary
Green on pin 3 V5
Secondary for 8 Ohm
