****** Audio 2" Drake OT color codes? MightyMike?
- mightymike
This layout is for a 1.5 OT and a 2.5 ****** PT in a 12000.
http://mightymike1.home.comcast.net/images/Stock67.gif
Should be the same color wires as you.
Just one word of caution for anyone using that layout.
Just watch out for 2 mistakes on my layout.
Vol2 input jack's ground (the black wire going from that input jack to the pot buss) is to the wrong terminal on the v2 input jack. It should be over one terminal, where the 1 meg is. Like the way Vol is drawn
So just copy Vol 1 right next to. It's drawn correct
And I forgot to draw in the green wire going to v3.
Other than that your complete wiring for both trannys is all there.
enjoy
enjoy
- rockstah
thanks Mike - your choke wire placement is different than what i use - the wire from the PI cap is different too... is this correct or is dans wacked? have you compared this layout to dans 67-68 transitional layout?mightymike wrote:This layout is for a 1.5 OT and a 2.5 ****** PT in a 12000.
enjoy
http://homepage.mac.com/gaden/.Public/6 ... Layout.pdf
- mightymike
they're both equivelent
either way is fine if you look there a dash yellow going underneath to the same point. PI is the same difference.
TomAto/Tomato
Here's some more pics of my 10000 in project.
http://mightymike1.home.comcast.net/images/10000a.jpg
http://mightymike1.home.comcast.net/images/10000b.jpg
All the holes are cut, gett'n ready to start heaters.
TomAto/Tomato
- rockstah
i figured 6 of on half dozen of the other. was just curious. and how did you come to this layout? - i have never seen it done like this.mightymike wrote:they're both equivelent
TomAto/Tomato
- mightymike
- 5150loveeddie
Are you guys still wondering Chris's color codes????
- mightymike
I haven't talked to Chris yet.
Does this look right?
Merrens 2" Drake Hook Up:
Drake 2" El 34
(input) side
Primarys twisted together
Red v5pin3 ? double check these 2 wires aren't backward or tubes fry
WHite v6pin3 ? double check these 2 wires aren't backward or tubes fry
CT
Brown to turret in the upper right corner of my tone board where choke and wire from HT fuse meet
Output Side
yellow 4 ohm
green 8 ohm
Grey 16 ohm
Common
Orange to Grounded side of Speaker Jack
Drake KT 66 Version
(input) side
Black v6pin3 ? double check these 2 wires aren't backward or tubes fry
CT
Brown to where choke goes on Filter board
Output Side
yellow 8 ohm
green 16 ohm
Blue-------------Don't Use..For PA No 4 ohm
Common
Drake 2" El 34
(input) side
CT
Output Side
yellow 4 ohm
green 8 ohm
Grey 16 ohm
Common
Drake KT 66 Version
(input) side
CT
Output Side
yellow 8 ohm
green 16 ohm
Common
- 5150loveeddie
Drake el34 OK
Let me check the kt66 one.......brb
- rockstah
thats not how i have my el34 1.5 of chris's wired and he said mine was correct.mightymike wrote:I haven't talked to Chris yet.
Drake 2" El 34
(input) side
CT
Output Side
yellow 4 ohm
green 8 ohm
Grey 16 ohm
Common
Drake KT 66 Version
(input) side
CT
Brown to I forgot.. I'll have to check my JTM 45/100
To ground right?
Output Side
yellow 4 ohm
green 8 ohm
Blue 16 ohm
Common
red and brown go to tubes - white goes to board.
output side:
brown ground
black 4ohm
yellow 8 ohm
green 16ohm
here is the picture he looked at and said it was correct -
- 5150loveeddie
2" KT665150loveeddie wrote:Drake el34 OK
Primaries: RED/BLACK (pin3)
CT: Brown
Green= 16ohms
Yellow= 8ohms
Blue= DONT USE THAT ONE DANGER......that one goes to a PA like in the old days, there is NO 4ohms on this OT
Orange=Common
- 5150loveeddie
Mark, your OK, the 1.5" DAGNALL copy doesn't have the same color code as the 2" Drake copy!!!!rockstah wrote:thats not how i have my el34 1.5 of chris's wired and he said mine was correct.mightymike wrote:I haven't talked to Chris yet.
Drake 2" El 34
(input) side
CT
Output Side
yellow 4 ohm
green 8 ohm
Grey 16 ohm
Common
Drake KT 66 Version
(input) side
CT
To ground right?
Output Side
yellow 4 ohm
green 8 ohm
Blue 16 ohm
Common
output side:
brown ground
black 4ohm
yellow 8 ohm
green 16ohm
- rockstah
ok!5150loveeddie wrote:Mark, your OK, the 1.5" DAGNALL copy doesn't have the same color code as the 2" Drake copy!!!!rockstah wrote:thats not how i have my el34 1.5 of chris's wired and he said mine was correct.mightymike wrote:I haven't talked to Chris yet.
Drake 2" El 34
(input) side
CT
Output Side
yellow 4 ohm
green 8 ohm
Grey 16 ohm
Common
Drake KT 66 Version
(input) side
CT
To ground right?
Output Side
yellow 4 ohm
green 8 ohm
Blue 16 ohm
Common
output side:
brown ground
black 4ohm
yellow 8 ohm
green 16ohm
- 5150loveeddie
Finally............ouf
- mightymike
