Wiring Diagram for a 100 watt PT
I want to double check my thoughts before the point of no return.
A laydown Heyboer 100 watt 1203-80-1 (putting together a superbass with '67 era specs).
Left side: (top to bottom)
COM
120
220
240
16AWG solid green
16AWG green with yellow stripe
16AWG solid green
22AWG solid blue
22AWG solid blue
Right side: (top to bottom)
178
152
COM
152
178
Could somebody review the connection points for each of these wires?
I would really appreciate it!
COM
120
220
240
16AWG solid green
16AWG solid green
22AWG solid blue
22AWG solid blue
178
152
COM
152
178
Uh oh!
I found a few answers, still a few questions though. How's this look?
(Heyboer laydown for 10,000 series superbass circuit. Serial number 1203-80-1 HTS 8205-1 9960646)
Left side:
COM run an orange wire from tab to the mains 4 amp fuse holder
120 run a red wire from tab to the lower two terminals of the power
switch
220 leave tab on tranny alone
240 leave tab on tranny alone
16AWG green- twist with other green 16 AWG wire then to pin 2 or 7 of V7
16AWG green/yellow stripe- to ground lug of nearby filter cap.
16AWG green- twist with other green 16 guage wire then to pin 7 or 2 of V7
22AWG blue- to bias supply on main board
22AWG blue- bias winding common tap, to chassis lug
Right side:
178 ?
152 leave tab on tranny alone?
COM ground to a lug on the chassis?
178 ?
The right side is not so clear to me right now. Thanks in advance for any help!
Left side:
switch
Right side:
178 ?
178 ?
- Flames1950
You've got the left side fine. The right side will run either the two 178 taps or the two 152 taps -- the 178's giving you a higher final B+ voltage than the 152's -- a blue wire from each to the AC sides of your bridge rectifier. I think for the '67 you'll want to take the center tap to the junction of your two mains filter caps (the "+" of the first joining the "-" of the second) but you might check Dan's '67 layout to be sure, but I'm pretty sure it should be a voltage doubler arrangement and hook between those caps.
- Flames1950
Yes, and it makes no difference which goes where.Metal Handles wrote:OK, after reviewing Dan's layout, do I run the two B+ (178 taps) to the top two tabs on the standby switch? (which then runs to the power board)
If so, I assume there is no difference which of the two B+ (aka HV Secondaries?) wires go to either of the top two standby switch tabs.
- Herec
- novosibir
Doesn't matter!Herec wrote:Does it matter which bias wire goes where, like which one goes to the board and which one to ground with this tranny.
Larry
