Hi Everybody.
I have finished and tested my 50 watt build. Here is the clips that I made. Does they sound like 50 watt to you?
https://soundcloud.com/alexander-drobit ... -humbucker
https://soundcloud.com/alexander-drobit ... aul-bridge
https://soundcloud.com/alexander-drobit ... neck-clean
The settings are the same for all clips
Bright channel, Presence, Bass, Mid and Treble are on noon, Volume on 11
For strat clean i just backed off volume on guitar.
Alex.
Does it sound like 50 watt? Sound clips
Re: Does it sound like 50 watt? Sound clips
Sounds right on the money to me! Nice work! Which kit did you use?
Basically it is metro amp kit except that I ordered capacitors and tube sockets from a different source. I used classic tone transformers.
Also my advice don't try to save on tube sockets and order them from metro amp. I have two bad tube sockets which I need to replace.
Yeah, I usually go ceramic but I went belton on the preamp tubes and ceramic on the power tubes this time. I have the Classic Tone OT and like the change it made from the Traynor Hammond OT I had in there.guitarist1977 wrote:Basically it is metro amp kit except that I ordered capacitors and tube sockets from a different source. I used classic tone transformers.
Sounds good. I don't use anything close to thoses settings though. I like Mids treble and Bright Vol all on 11 and everything else on 0.
