RIGHT....UPDATE.
I put the tubes in tonight, but no guitar, or guitar cable. Switched her on. Usual background hum in standby, tubes all glowing a little. Then flicked to 'on' and a much louder hum/hiss from the speakers.
Checked voltages. Seem pretty good, except ONE area on V2. I couldn't get a measurement from Pin1 and the popping noise over the speakers as my probe touched this pin was very loud and noisy. Similarly pin 7 was too, although I got a reading here. Might have to check connections, but this is the area where there is a 100K resistor (which I've checked and is reading 97k). On one side of the resistor at pin 1, it's very noisy putting the probe there. And pin 7, the same side of that resistor, noisy too. Pin 6 though, the opposite side of the resistor is ok for a reading.
Should that wire from pin 1 to pin 7 be touching the metal centre or not? At the moment, it is not.
Ok. Some things of note. The Mullard XF4 in v4 was slightly microphonic I think. Tapping on it with a chopstick when the amp was 'on' resulted in a tapping through the speakers. I replaced this with an EL34 from my Orange amp, and that has cured that (but not the loud hum/hiss through the speakers).
Of even bigger note.......My NFB resistor is a 100K resistor, currently going to the 4ohm tap. However, placing my multimeter on either side of that resistor results in only a reading of 6.7k?! Could this be the cause of my issue?
*******EDIT************
Actually, it's not really a HISS.....just a much louder 'hum' than when on standby. It might be alright, but I don't think my bass head hums this much with no input.
Might try a guitar in it tommorow, once I know that that buggered 100K feedback resistor is or isn't causing the issue.
*************VOLTAGES*************
V1:
Pin1: 133 (expected: 180)
Pin3: 1 DC or 1.5VAC (expected 1.6)
Pin6: 193 (expected 160)
Pin8: 3 DC or 2.6VAC (expected 1.6)
V2:
Pin1: No reading, bloody noisy when probe touched (expected: 140)
Pin3: 1 DC (expected 1)
Pin6: 284 (expected 250)
Pin7 (noisy): 179 (expected 140)
Pin8: 180 (expected 140)
V3:
V4:
Pin3: 441 (expected 380)
Pin4: 442 (expected 390)
Pin5: -32 (expected -30)
V5:
Pin3: 444 (expected 380)
Pin4: 443 (expected 390)
Pin5: -33 (expected -30)
