Some of you may already do this but I just figured it out. I basically need a 3 channel amp consisting of clean, crunch and lead channels. I've been using the bright channel with a Radial Tone Bone Hot British and getting a volume boost for leads with a Time Machine Boost, modern side. I wasn't real happy with these results.
I removed the stock 500 pf bright cap from the bright channel and put it on the normal side which makes the channels sound pretty close, the normal channel is just a little fatter. Then I took my old EH Switchblade and plug into each channel with the normal channel set at higher volume. I run my wah, Hot British and phaser before the Switchblade. By doing this I get 4 channels, regular clean, louder clean/slight break up, rhythm crunch and louder lead. I run my delay in the effects loop and am totally happy with the sound. It definitely sounds better than my TSL and I don't need two rigs for the clean/ dirty setup.
3 Channel Metro JMP 50
