Hey guys...anyone have thoughts or preferences regarding placement of purple negative feedback wire on a 50 watt kit. Manual says to attach to output terminal but gives 4, 8, and 16 ohm tap options. Any opinions?
Kevrockitt
50 watt negative feedbak question
- elronhoover
Re: 50 watt negative feedbak question
I messed around with the taps and R values, and ended up staying with the NFB stock values and the common terminal with a 16 ohm cab. Sounded best to me for my playing, though I think comparably with this setup the 8ohm/8ohm cab sounds ratty and 4ohm/4ohm cab sounds even rattier, just more crappy/splatty as you go down in Z, but I only ever use a single 16 ohm cab anyways. My presence knob never goes much past 9:00 either FWIW..kevrockitt wrote:Hey guys...anyone have thoughts or preferences regarding placement of purple negative feedback wire on a 50 watt kit. Manual says to attach to output terminal but gives 4, 8, and 16 ohm tap options. Any opinions?
Kevrockitt
Dave
guess you only get one chance in life to play a song that goes like this.....
Thanks Dave.
- Big Mike
Think I went 100K right to the speaker jack....I might bring it down a tad. It's a bit gainy for me.
Metroamp kit JMP50 - CM OT
Marshall 2550 Jubilee
Scumback Speakers
Scumback Speakers
